APR studs and Roller rockers
Old May 11, 2007 | 08:43 AM
MR NICE's Avatar
MR NICE
Default APR studs and Roller rockers
Hi,just wanted another opinon on my rocker arm install,I'm using arp 7/16 studs,Comp guide plates, pushrods,Comp mag roller rockers,I installed rockers and set preload per FSM,after I was done I noticed a couple rocker arm nuts were adjusted a few threads off from the rest? went through it again with same results is this anything to worry about?TIA
Old May 11, 2007 | 10:42 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If there no burrs on the new guide plates, the new studs are torqued to spec and the push rods are properly seated in the lifter piston cups and the RR cups I wouldn't worry about it.
I used the EO/IC method of determining zero lash and setting lifter pre-load but didn't notice where the poly locks were on the stud threads.
