vortex rammer air intake
Old May 12, 2007 | 09:56 AM
95 blue pig's Avatar
95 blue pig
Default vortex rammer air intake
Has anyone used the Vortex rammer system . Zip products has it for $280 Ecklers for $295. is it worth putting on? they claim 22 hp. & 3.5 tenths Quicker in the1/4 mi. my 95 is mostly stock. Just L.T. headers no cats , & Borla S.S. cat back exhaust. Also 125 hp. wet nitrous.
Old May 12, 2007 | 11:28 AM
RonRed89's Avatar
RonRed89
You will not get anything near the numbers you mention above, and the quality of the Rammer is suspect based on other posts here, and based on my observations (I returned mine). You'd do really well with a K&N/Open Lid type setup.
Ron
Old May 12, 2007 | 02:31 PM
hgh pwr's Avatar
hgh pwr
If you want one i will sell you mine for 150 dollars,pm me if your interested.
Old May 12, 2007 | 05:07 PM
pipe's Avatar
pipe
The Vortex Air Rammer is a good idea but it's made from crappy materials. A lot of guy's on here complain that the plastic air box warps badly from the underhood heat. Pipe
Old May 12, 2007 | 09:26 PM
C485tomg's Avatar
C485tomg
I was almost set to buy one-thanks for the information. I just got burned on a throttle body, don't need to get burned on something else!
Old May 12, 2007 | 09:31 PM
Demonic85's Avatar
Demonic85
Even with a good cold air intake kit, you will be lucky to gain 5-10 HP. You might want to think about saving your money for a better upgrade.
Old May 13, 2007 | 06:13 AM
95 blue pig
thanks for the imput. I did not think it would really give 22 HP.
Old May 13, 2007 | 11:05 AM
sami85L98's Avatar
sami85L98
I had twice but did not see any difference in power but i love that hissing sound and appearance
Old May 14, 2007 | 08:58 AM
d48mclain's Avatar
d48mclain
I threw one away if that tells ya anything. Didn't have the ***** or the conscience to pass that piece of crap on to anyone else.
Posted this numerous times and swore I wouldn’t do it again, but…….. I’ve found that if you do the cut lid mod and take TWO air cleaners (One K+N and any ol piece of whatever) removing the guts of the bottom and just keeping the frame…..it works as good as anything you can buy.
My car makes a little more than most with the best run well over 480rwhp N/A so it probably is a bit more sensitive to air needs. Doing the cut lid with just a single K+N cost me about 20 hp on the top where it needs the most air as a single filter is too close to the base of the intake cutting off air. By adding the second filter frame below the K+N as a spacer, brought the car back up into the 480 range again. Dynoed with the POS Vortex, no filter intake at all with air going directly into the MAF and my double filter trick, all came out exactly the same on the dyno.
So there ya go…….save your money for something like sex n drugs and don’t waste it on the Vortex. I mean it works, it will just fall apart on ya and I also found the car to run a little cooler when it was removed.
Old May 14, 2007 | 10:20 AM
Aardwolf's Avatar
Aardwolf
Two filters make more power? The design of the filter area must be different with your car then my L98. I haven't looked at a '96 filter. I don't see how it would help with my '88 or even fit under the hood. Do you have a picture of this mod?
Old May 14, 2007 | 12:26 PM
LT4POWR's Avatar
LT4POWR
You're not reading it correctly. I haven't tried it (yet), but what he's saying is (inside one cut lid box) used one regular K&N on top, then under it (on the bottom) use only the frame of another cheap filter as a spacer.
Old May 14, 2007 | 01:15 PM
Aardwolf's Avatar
Aardwolf
Two stacked filters for more power?
Old May 14, 2007 | 01:25 PM
LT4POWR's Avatar
LT4POWR
Old May 14, 2007 | 04:30 PM
d48mclain's Avatar
d48mclain
No kidding! In that case.....try three and you'll make even more power.
Old May 14, 2007 | 04:45 PM
Aardwolf's Avatar
Aardwolf
So it's like a TB spacer? You should sell them!
To vortex rammer air intake
