Headgasket Phase 2, Help and Advise Requested.
Sometimes the gaskets just seep slightly and its difficult to find out where.
Be sure to have a machine shop check your heads for flat and true, before you bolt them back on.
RACE ON!!!
And while you're at it, have them check them for cracks too. I'd also advise showing your gaskets to a good tech for analysis. They can likely tell for sure when looking at them in real life if there are any suspect or obvious problem area(s).
Your block has two coolant drain holes, one on each side of the block, down low, just above the oil pan rail, very close to the center of the block, lengthwise. If you are working on an '87 as your screen name suggests, the hole in the left side of the block is plugged by a pipe plug. The right side drain hole has the knock sensor installed. If you care about checking the water in the cylinders for signs of leakage, you will have to drain that side of the block for any meaningful signs. Otherwise, it isn't important. Just clean up the water right away to keep it out of the pan.
RACE ON!!!
Removing the knock sensor and oil cooler line will drain the block, but you want to get the heads drained too. To accomplish that, remove the gage sender on the right head between 6 & 8.
Vacuum all that coolant out with a shop vac and then lube those cylinders with some 30 wt before they rust. Crank the engine over by hand to put each cylinder at BDC to make sure you coat everything you can with oil. Drain the pan.
Oil those suckers up..They are starting to rust already
My recent replacement took my buddy and I a good 10 mins each of inspecting my head gasket before we found what looked to be a spot just slightly "not normal" and on further inspection, once we pulled the gasket off, we found the slightest discoloration where coolant had seeped in. It was SOOOO small that you could barely find it, but it was there.
The gasket itself was not cracked at all, just a little more worn looking around one of the holes than anywhere else.
I see a few spots on yours that could have possibilities to do just that.
Mine wasn't AS bad though, so I still drove mine for another month or so until it started getting really bad (it took me a while to figure this out). Anyway... my water pump died, thus causing it to overheat a lot, thus blowing the head gasket.
I didnt have anything dripping out, but when I drained the oil, it was full of water also.
When I pulled my head off, one cyl was full of water. (Same thing 3-4 years prior as well)
As long as you make sure the oil is drained and all is empty of water/coolant, you should be ok. Just leave the drain plug off the whole time you work on it to make sure it ALL drips out.
Here are a few pics of my head gasket replacement several months ago:
Nothing looked cracked either, but from the discoloration we noticed something wasn't right:
See the little rough spot? That's all it took to weaken it enought to where the water seeped under the gasket and into the cyl:
here's the cyl with coolant in it:
The other cyl's had some coolant/water in them, but it was just from when we pulled the head off and it dripped in. The main one with all the coolant in it was the "bad" one.
