Taking out a battery for a 95
Old May 13, 2007 | 01:02 AM
1995_Corvette's Avatar
1995_Corvette
Default Taking out a battery for a 95
I have the vent panel out and the have access to the battery.. after reading the 101 projects for your C4.. it says the battery comes out sideways.. really.... the batttery terminals are off and it moves a bit to the right.. but anyone have instructions after that.. it does not move over enough to the right so i can take it out. Any ideas?
Mike
Old May 13, 2007 | 01:30 AM
bogus's Avatar
bogus
there is a single bolt behind the battery that retains it to the base.
Old May 13, 2007 | 01:34 AM
1995_Corvette
there was a bolt to the right that i took off.. it looks like it hold the battery to the base...
Old May 13, 2007 | 02:16 AM
bogus's Avatar
bogus
from there, the battery should lift up and out. there is a small ridge.
Old May 13, 2007 | 10:34 AM
Red Dwarf's Avatar
Red Dwarf
Try this site http://www.corvettemagazine.com/2001...ttery/bat1.asp
Old May 13, 2007 | 10:43 AM
jimmers's Avatar
jimmers
Old May 13, 2007 | 11:39 AM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
Remove the side panel. Disconnect the cables. Remove the hold down bolt and it'll slide right out.
To Taking out a battery for a 95
