injectors
Old May 13, 2007 | 08:13 PM
dagrump's Avatar
dagrump
Default injectors
will it be safe for me to run 24lb injectors with a procharger p600b? i'm not planning on using a fmu. i just don't know if they are large enough. any help would be appreciated.
Old May 14, 2007 | 01:00 AM
Mo_Bandy's Avatar
Mo_Bandy
If you are not planning on using an FMU you need to be in the neighborhood of 42 lbs... also you may need a supplimental fuel pump...
This pretty much depends on the amount of boost you are running... But 42 is a good number for say 6-8 pounds of boost..
Also you need to be sure that you are handling the amount of advance you are running... like a MSD BTM or the means of programming some retard on your higher RPMs...
Hope this helps...
MO
