Windshield wipers will not work
Old May 13, 2007 | 08:57 PM
sidewheeler's Avatar
sidewheeler
5th Gear
Default Windshield wipers will not work
I have a 95 that only has 80k miles on it. the windshield wipers quite working!!! the arms are almost returned to the down position. nothing happens when I turn on the wiper switch. someone mentioned that they are ground switched, so how do I trouble shoot this?
Old May 14, 2007 | 11:12 AM
Red Dwarf's Avatar
Red Dwarf
What have you checked so far? Fuse???
Old May 14, 2007 | 05:29 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Corvettes have windshield wipers?
Buy a FSM.
Check the fuse then the motor then the wiper motor cover(circuit board). If you have the low tire pressure system check the capacitor in the wiper motor 2 way jumper harness.
Buy a FSM.
Old May 14, 2007 | 10:16 PM
DVNCI's Avatar
DVNCI
dumb question but have you checked the underhood harness connection? they can slip out if not properly seated
Old May 18, 2007 | 03:56 PM
Cmanhome's Avatar
Cmanhome
I had a problem on my 95 after replacing the wiper blades at the tire place. They would occasionally stick when in the down position, they were just jamming in the mechanism.
To Windshield wipers will not work
