elec. water pump ?
Old May 13, 2007 | 09:04 PM
pipe's Avatar
pipe
Default elec. water pump ?
Hey guy's if I install a elec. waterpump on my Vette will it be reliable when driving it on the street? How long will it last and will I gain anything when I take it to the Strip? Where can I go with the small heater hose that goes into the stock pump? Will I have to modify any of the brackets that mount on the front of the stock pump? THANKS FOR ALL THE HELP Pipe
Old May 13, 2007 | 09:12 PM
rodj's Avatar
rodj
What year model?
Old May 13, 2007 | 09:13 PM
rssshen vette's Avatar
rssshen vette
Old May 13, 2007 | 09:18 PM
f451degrees's Avatar
f451degrees
profile say's it's a 90, I'm also interested in this thread for my 91
see ya on the road
Old May 13, 2007 | 09:31 PM
pipe's Avatar
pipe
Sorry Guy's it's a 90 auto with some bolt on stuff. Pipe
Old May 14, 2007 | 12:53 PM
rickneworleansla's Avatar
rickneworleansla
I recently bought a Meziere HD electric water pump. I could have really used it between runs a couple of weeks ago at the track. My temp on the last run was around 204 degrees. With the EWP you can hook it up to run the pump with the engine off between runs at full pressure. I believe it gets full pressure all the time which could benefit in traffic also. I heard it may be good for around 5 to 8hp. There shouldnt be any problem on the street as long as you run a light indicating failure. You can contact the company of the WP you are looking at for life expextancy. Ask yourself how much you drive the car each day. For me it's only about 20 minutes each way to work and a few hours on the weekends. It should last a long time.
Old May 14, 2007 | 04:21 PM
pipe's Avatar
pipe
Thanks for all the replys. Still wonderin what to do with the small heater hose that goes in the side of the stock pump? I guess I can just run a ground and hot wire with a toggle in the cockpit to turn the pump on and off. Pipe
Old May 14, 2007 | 06:30 PM
d48mclain's Avatar
d48mclain
Had one for I guess four years and I'm a believer in them. today the thermo said 91 degrees and it never went over 174 degrees in rush hour stop n go traffic. Running a stroker motor with a lot of compression so if an N/A was to run hot, it would be this one.
Do a 160 degree thermo, clean both your radiator and condensor and program the fans to come on in the low 160 range and I'd expect you'd be quite happy. David Vizzard says cars make the most power around 170 degree water temp.
Quite honestly not sure exactly what you do get in addition power as that's something I've never played with on the dyno but I wouldn't hold my breath for anything earth shaking, it's all good however.
Old May 14, 2007 | 07:36 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
85vet has an electric WP on his early C4 all the accessories running.
PM him
To elec. water pump ?
