Dropping the D44
Old May 15, 2007 | 10:17 AM
LT4POWR's Avatar
LT4POWR
Default Dropping the D44
Okay, much to my dismay I’m gonna drop my D44 and ship it off (can’t find anyone local) to get some gears installed. I’ll be doing it in my little garage w/ the car on jackstands. Anybody got any special tips for doing this? The job looks pretty straight forward. Also, are there any specific tips/advise for removing the rear spring? Thanks
Old May 15, 2007 | 10:46 AM
fredk's Avatar
fredk
I just happened to do this job. Use a jack on the steel part on the end of the spring take the nut and cotter pin off and slowly lower the jack.
It is not a bad job just make sure you remember where everything goes. The C beam is a bit of a bitch to line up so just use a jack on the tranny and lift until the holes line up. This will save you a good buck on the gear change.
Fred
Old May 15, 2007 | 11:51 AM
BlackC6LS3's Avatar
BlackC6LS3
The best tip out there.
Old May 15, 2007 | 12:17 PM
edoad's Avatar
edoad
I just did this on an 85. Same as above advice but make sure you have the car fairly high of the ground. The spring will come down about a foot past the end of the bolt.
Old May 16, 2007 | 08:49 AM
LT4POWR's Avatar
LT4POWR
Thanks guys
Old May 16, 2007 | 10:24 AM
C4DC's Avatar
C4DC
St. Jude Donor '06
Remember to retorque the front C beam bolts when you're done. Mine loosened up for some reason.
Old May 16, 2007 | 04:13 PM
elkabong's Avatar
elkabong
Originally Posted by BlackRoseLT1
I used this Tip as a guide when I did a D36 to D44 swap on my 84. The hardest part is the C Beam. Make sure you have a good jack under the trans to support it. You will need that support until the D44 comes back and you reinstall. I did mine on my back as well. Have a friend come over to give you a hand when you drop it - and reinstall it. The extra set of hands are worth it.
You may have problems with "While it is up on jackstands I might as well.............." Actually it is a good time to do whatever.
To Dropping the D44
