95' New Top-Need Adjusting Inst.
Old May 15, 2007 | 03:28 PM
CAJUN C4's Avatar
CAJUN C4
Default 95' New Top-Need Adjusting Inst.
Anyone have the procedure for adjusting the fit on a new top?
Old May 15, 2007 | 05:47 PM
Fast Eddiz's Avatar
Fast Eddiz
I have top install instructions I'll pass along if I had an email address for the attachment.
Old May 16, 2007 | 03:21 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
I just tightened one bolt on the front bracket then moved them around until I had a good even seal across the front of the car. I spent about 30 minutes getting it right.
Old May 16, 2007 | 08:32 AM
CAJUN C4's Avatar
CAJUN C4
dschaff@fairengineering.com
Thanx
Old May 17, 2007 | 08:53 AM
CAJUN C4's Avatar
CAJUN C4
Ed..Any Luck?
Thanx..Cajun
Old May 17, 2007 | 01:17 PM
sraft's Avatar
sraft
When I did mine, I removed the all the trim from the windshield header which exposed the bolts that allow you to loosen the front hold-down points for the top. I then also loosened the rear hold down points on the car and any adjustmentable points on the top and placed the top into position. Now that everything was loose, I was able to preciesly position the top so that it was aligned, then carefully tightened all the bolts untill they were secure. The top now drops right into place and tightens nicely without any binding.
Old May 17, 2007 | 03:32 PM
CAJUN C4's Avatar
CAJUN C4
Got em
Thanx a bunch Ed
Old May 22, 2007 | 09:00 AM
CAJUN C4's Avatar
CAJUN C4
Thanx Guys for all your input
Cajun
To 95' New Top-Need Adjusting Inst.
