changed my t-stat and now it's missing..
Old May 16, 2007 | 12:14 AM
hkphoto's Avatar
hkphoto
Default changed my t-stat and now it's missing..
changed my t-stat and now it's missing..flushed system water everywhere..must have soaked the opti spark...will it dry out or do i have to take it apart or???? 94 C4 LT-1 with a super charger..
thanks hk
Old May 16, 2007 | 01:09 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I've seen this thread about 100 times. It always ends the same. Expensive.
Old May 16, 2007 | 08:02 AM
Wheelman's Avatar
Wheelman
Originally Posted by hkphoto
changed my t-stat and now it's missing...
Thermostats don't just disappear you know...
Old May 16, 2007 | 08:12 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
But it seens a proper sentence subject can!
Old May 16, 2007 | 08:22 AM
vetteblack's Avatar
vetteblack
Supercharger!
Old May 16, 2007 | 08:26 AM
edar's Avatar
edar
most liekly you got some coolant where you weren't suppose to. Possibly in the Opti. Did you spill a gallon or so of coolant?
If so, remove as much superficial moisture as you can let it bake out a bit for a day or in the sun or if in a garage with the hood open. It should be fine in a couple of days. Good luck.
Old May 16, 2007 | 09:44 AM
DonF's Avatar
DonF
Sounds like the Opti Spark to me, I have not heard of being able to dry it out though. I hope it will & save you $$$$ odd Luck Don F
Old May 16, 2007 | 09:59 AM
hkphoto's Avatar
hkphoto
Default can the opti spark be taken apart??
can the opti spark be taken apart??...or does it have to replaced???
please no stupid replies
Old May 16, 2007 | 07:16 PM
hkphoto's Avatar
hkphoto
Default I put a fan on it over nite and now it's fine...
I put a fan on it over nite and now it's fine...I quess it dried out..thanks for all that helped...
To changed my t-stat and now it's missing..
