Question on what size injectors?
-383
-10.5 CR
-AFR "Eliminator" 195cc *1040 heads
-Miniram
-58 MM TB
-JE Pistons
-Eagle Crank
-Lunati Pro Mods Rods
-Stock ECM for now
I am aiming for 400rwhp. What injectors do you think? I dont want to max out the duty cycle. I am not an expert on injectors by any means, and either are you Sami.
I would love to hear from guys who have built stroker's while using the short runner Miniram intake. If you are guessing then I dont really need to read your answers. I hope that doesnt sound mean, but it would be better to read answers from guys who have been there, and done that!!!!My gut says 36's. Some say 30's, and some say 42's.
we know there are certain racer-x weekend-only dedicated 1/4 milers on this board who will tell you all about power down the strip and virtually ignore duty cycle. they like the leaner injectors because they're used to rebuilding their engine every 1-2 years because that is their whole life, and don't really care about medium-term risk to the regular driver guy.
a simple search will reveal those guys.
if you're at 80% for street duty then you'll be fine.
Is your nitrous shot going to be dry or wet? Since you brought that up in an injector thread, you must be intending to go dry. A 150 HP shot is quite a bit for a dry shot, but I've heard of guys doing it. In my opinion, if you really are going to stick the bottle on it and shoot a 150 shot, you should plan to use a wet system. There's no need in suffering the tuning problems associated with a big injector on your car, you'll be on motor 99% of the time, installing injectors to support that 1% of the time you'll be spraying and suffering tuning difficulty for the 99% of the time you'll be on motor doesn't make much sense to me.
Let us know what you decide to do.
This was a supercharged car with a strong fuel system, I.E. sumped fuel tank, -10 feed line, Aeromotive A1000 pump, -8 lines to 1/2" I.D. aluminum fuel rails, -6 return line.
Assuming the 400rwhp goal is attainable (and I'd hope it is), and the fact that you plan a "maybe" shot of nitrous, I'd step up to the 42's right from the get go. More importantly, IMHO, I'd also plan a fuel system upgrade. Not saying you need to spend a grand or more like I did, but with stock size lines and just a high volume intank pump to feed 42# injectors, you'd be asking for trouble IMO. Reason I say this is because I went from 30#ers, stock lines/rails and intank pump to 42's with stock lines/rails and intank pump and immediately started seeing a drop in WOT fuel pressure readings. No laptop or scan tool around will tell you that you're getting ready to melt an engine due to fuel pressure loss.
FWIW, as you know I'm a convert from the blower/nitrous Mustang camp, and not long ago I tuned one of my supercharged Mustang buddies' car on a Mustang Dyno. He used 42's and comfortably makes just a hair over 400rwhp, on pump gas, in any weather. I have him setup rather rich, but the car is 100% trouble free and he has no worry of going lean.
One of my own other cars, with a 100hp dry shot (30# injectors) made 372rwhp/434rwtq and stayed plenty safe on the a/f ratio.
Bottom line, although 42's "may" be a little big, you'll have plenty of safety cushion. Much better to have injectors slightly too big, than to have them slightly too small.
edit: I agree w/neat that a wet shot would probably be easier to tune for, although I've personally ran a 175 dry kit on a non GM car without a worry.
Yeah. I thought about those SVO's.
Hard to argue with neat's advice
When u r ready for spray, get NOS brand 05151 kit, its made for Tpi car, and iam sure u will not have problem hooking with miniram too. Its a wet system and NOS brand is quality. Also get 15 lbs bottle instead of 10 lbs, 10 lbs will be "Gone in 60 sec's". It emptied too quick.
Good luck. is ur's is 4+3 or ZF 6 spd, or u planning to replace clutch? how about a short throw shifter too. Hey hotrodding never stops.....
Also do u already have or goin to or not at all considering MSD 6AL box, if u dont have and have plan for than buy crane fireball it comes with reard box separate too for 319 and its quality and cheaper than msd, i saw in pete's car man its awesome piece compare to my MSD funny looking box. Hope to see u soon if everything goes well. sami
BTW, I also plan to run prob a 150 shot in the future.
