Cloyes Timing Chain ???
Old May 16, 2007 | 01:56 AM
Ruff Rider's Avatar
Ruff Rider
Default Cloyes Timing Chain ???
I'm debating on the LT-4 hot Cam Kit.... If I go this way (most likely will) it seems like a good idea to go with the Cloyes timing chain part #9-3151. Question is, Are there other sett's out there that r just as good but cheaper ??? I cant find the Cloyes under $355.95, GM parts direct offers part #12370835 for $230.78 but is it as good. Any help/guidance in this area would be appreciated...... ....thanks in advance.
Old May 16, 2007 | 01:58 AM
STL94LT1's Avatar
STL94LT1
Go with an electric water pump and you can run the ~$80 Cloyes 9-3145 true double roller.
Old May 16, 2007 | 02:07 AM
Ruff Rider's Avatar
Ruff Rider
I did not no that, I have the Meziere in the box waiting to install along with a DeWitt's radiator and a few other parts.....thank you
Old May 16, 2007 | 02:57 AM
JAKE's Avatar
JAKE
Yep, that's the ticket.
I have a brand new, in the box 9-3145 that I just sold to a Forum member for $50
I bought it, not knowing I'd have to remove all the stock water pump stuff behind the timing chain cover and run an electric water pump.
I decided not to go that route and ordered a Cloyes 3039 from Summit for about $80 which'll allow me to keep running a stock type water pump.
Jake
Old May 16, 2007 | 03:09 AM
STL94LT1's Avatar
STL94LT1
Just found that timing set on Summit's site. Didn't know one was availible that cheap, for our cars. Looks like a nice stock replacement.
Old May 16, 2007 | 08:09 AM
Desert1957's Avatar
Desert1957
Default Help me find your 3039# part
Jake
Jake,
Is this a Cloyes Part#? (3039) , I am looking to do this job on mine soon.
thanks Desert
Old May 16, 2007 | 01:26 PM
JAKE's Avatar
JAKE
Originally Posted by Desert1957
Jake,
thanks Desert
CLO-C-3039 is the number.
Jake
Old May 16, 2007 | 01:43 PM
billybonesmusic's Avatar
billybonesmusic
does the electric water pump cool as good as a regular stock pump?
i want to do the electric pump also, what about the serpentine pulleys and brackets? i have the s/b 406
Old May 16, 2007 | 04:07 PM
STL94LT1's Avatar
STL94LT1
Don't know about other engines. But, our LTx water pumps are driven by the top timing gear. No belts or pulleys.
Old May 16, 2007 | 04:36 PM
JAKE's Avatar
JAKE
The water pump gear assembly is part # 10219554. I just ordered one today.
If you decide to go with a stock-type setup and need the gear assembly, you can check GMPARTSDIRECT.COM for a much better price than your local GM parts dealer. Close to a $40 savings.
Jake
To Cloyes Timing Chain ???
