TPIS exhaust Installed
Old Oct 21, 2001 | 09:20 PM
Vic'89's Avatar
Vic'89
Default TPIS exhaust Installed
Just had my TPIS catback exhaust installed.
This is the system that doesn't fit perfectly from TPIS. About 2 months ago, I tried to install it myself with no luck.
I took it to a shop and within an hour the exhaust was installed and I was on my way. The Ypipe need to be cut about 1.5 inches on both sides. I had the mufflers welded to the rear Ypipe.
The first thing I noticed is the exhaust is very loud. The car seems quicker, but we will find out next weekend at the track.
Hopefully I get the same gain in ET that 65Z01 got.
Vic
[Modified by Vic'89, 7:21 PM 10/21/2001]
Old Oct 22, 2001 | 02:16 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: TPIS exhaust Installed (Vic'89)
Vic, congrats. It was a long time in the doing but ain't it a sweet sound. If we get cool weather with a good baro you'll likely see 12s Sat.
Had mine out today for the first time since the universals got replaced in the right half-shaft. She was pulling very strong even in 80 deg weather. I'm realy anxious for the weekend to roll up. I'll be there Fri eve for some much needed practice on the tree. Hope to see you Sat.
Old Oct 22, 2001 | 02:36 AM
Raysur's Avatar
Raysur
Default Re: TPIS exhaust Installed (65Z01)
Are the pipes 2.5"? or 3"? Mandrel bend?
Sounds cool. :cool:
Old Oct 22, 2001 | 10:13 AM
65Z01's Avatar
65Z01
Default Re: TPIS exhaust Installed (Raysur)
The main pipe out of the cat goes 3" to 3 1/2" then splits into dual 3" into each muffler.
To TPIS exhaust Installed
