What bonding material to use ????
My Corvette pics is missing. ???????
-remove the license plate and the headlight covers.
-reach through the license plate hole and unscrew the headlight frames from the back (10mm bolts) and remove them
-remove all the lights by twisting them half a turn and then pulling from the back.
-reaching through the license plate and headlight holes, remove a ton of bolts/nuts (about 20) along the upper seam. They start out 7mm and transition to 10mm along the sides, and the studs stay in place. You have to reach in a really awkward way to get to some because the antenna bracket is in the way. Hope you have some good socket extensions, if not go invest in some.
-remove the lower bolts just inside the license plate hole, and the bolts outside near the muffler tips.
-remove both rear wheel wells (remove the allen bolts and they slide out)
-unscrew two more bolts on each side, on the seam just behind the rear wheel wells. They are awkward and require one of those wobbly-type extensions and I think an 8mm socket. Remove the tubular metal brace that uses one of these bolts.
-pull down hard on the section near the wheel well to disengage it from the studs that are pointing downwards, and then pull backwards on the whole rear clip and it should come off, unless you forgot some bolts (you probably did - so keep looking and feeling around).
-while it's hanging loose, unplug any remaining connectors from the clip.
I think that's everything. If not PM me.
