94 corvette starting problem
Old May 16, 2007 | 08:16 PM
94blackvette's Avatar
94blackvette
Default 94 corvette starting problem
I have a 94 corvette LT-1 corvette. I replaced the cat on the passenger side and when I was driving it home it died. I could get it started so I had it towed to the muffler shop I had the cat installed. They said it was pulling a code 16. So I replaced the optispark, still nothing, I ran some test and replace the ignition control module, still nothing. I checked for spark, it has spark. I check the fuel pressure, it has 40 lbs. I check the injecters for pulse, they all have pulse. I check the injectors with an ohm tester they are have the same ohms. I bought a brand new acdelco optispark. I cleared the codes and check for any new code. It is now pulling a code 42. Which is EST (electronic spark timing) my flow chart says check the wires from the ECM to the ignition modual, replace the ignition module which I did. It also say replace the ECM. It cranks over but will not fire. Does anyone have any suggestions first before I replace the computer. Please help me.
