1984 electrical problems
Old May 16, 2007 | 09:17 PM
stick105's Avatar
stick105
Default 1984 electrical problems
I have had a 84 for about 3 months now and have a major electrical problems.
1. I have a battery drain. I followed it down to the L.C.D. fuse. The stock dash cluster was not working at all and the lcd's were all sun cracked. I replaced the cluster with a rebuild.
2. The turn signal and hi-beam indicator on the new dash cluster will not light although the headlights and signal lights illuminate on the car.
3. My ground points on the frame or anything metal (valve covers) will light my test light when I touch these supposed grounds (test light clamped onto negative battery post and ground cable not connected to battery).
4. My headlights, turn signals,brake, interior, dash cluster, and driver info center have lights. all other lights don't work. when I turn the parking lights on I immediatly blow the 10amp light fuse.
Help me please!!! I don't have much more hair to pull out.
Old May 16, 2007 | 09:43 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
The corvette digital cluster repair guide on this site is helpful: http://www.batee.com/corvette/index.shtml
However, it sounds as if you have more issues than just the dash cluster
Gary
Old May 16, 2007 | 11:12 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
1st would be to get a FSM, great and best friend you can have.
2nd: If you use the search function, include archives you can get alot of into on most of your problems and testing procedures.
3rd: Agree, you have alot of small problems, pick one and start there...
Old May 16, 2007 | 11:17 PM
jfb's Avatar
jfb
The rebuilt cluster should not draw very much, "off", current and certainly should not light a test light connected in place of the lcd fuse (battery connected). If it does, you should get in contact with the rebuilder!
The turn signal and hi beam light you should first check that their ground wires (black) do go to ground with an ohmeter. Measure the resistance from the black wire to the neg battery terminal (battery cables connected). Then, with each turn signal flashing and the hi beams on, measure the voltage on the non ground wire on each lamp. You either have no 12v on them or their ground wires are open , or both.
You clearly have a short in your parking light circuit and you will have to trace the wires to see where the short is. You will have to check the front parking lamps and wires, rear parking lamps/wires, front and rear side marker lamps/wires, and the license plate light. Most likely one of the wires is pinched or its insulation is chaffed and touching ground.
Old Sep 25, 2007 | 09:07 AM
stick105's Avatar
stick105
This still has me baffled.
Old Sep 25, 2007 | 09:13 AM
stick105's Avatar
stick105
I have all of Gordon Killebrews publications and a factory service manual. I am mechanically inclined and have worked on cars, boats, trucks, farm equipment, etc, but this thing is possessed.
Old Sep 25, 2007 | 12:24 PM
jfb's Avatar
jfb
It is not possessed, it just has multiple problems. Fix them one at a time, don't try to fix them ALL at the same time and you will be fine.
Old Nov 21, 2021 | 04:51 PM
Wrench Artist's Avatar
Wrench Artist
1st Gear
Hey Stick105, Are you still out there? I recently bought a 1984 and I'm having the same electrical issue. Put my test light on negative side of battery, with cable disconnected, and if I probe anything metal, block, valve covers, hood latch it lights. What did you find?
Old Nov 22, 2021 | 03:35 PM
383vett's Avatar
383vett
Did you buy Stick105's car?
To 1984 electrical problems
