Try cleaning your sensors off and if no improvement,you can buy them from corvette salvage yards.
Bill, I did this already. Can you look at something for me on your car? Behind the drivers seat where the ABS equipment is, on mine there is a set of green and white wires going to a plug end. There is no place where this could plug in to open and someone has a resistor jumping the plug end green wire to the white wire and electric taped over. I doubt that it came that way but all the tech's here are of no help and cant find any info for me. Also seeing that there is no place where this could plug into maybe it did come that way???
Shimy, you really need the service manual to troubleshoot the ABS system. If you don't have one, search user Agent86 and terms like ABS. He posts a lot of links to .PDF pages for troubleshooting different components.
Rspreng, I may be interested in any of the sensors you have if no one else wants them. Shoot me a PM or e-mail with a price if you'd like.
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
If you could look I'd really appreciate it.
The resistor you speak of should be a diode. They look very similar. It may look like the previous owner taped it in, but that is how the factory did it. Genuine GM Quality from the 80's.
What tests have you performed so far and what were the results? Have you done a search for ABS threads and found my usual long response on how to test the early C4 ABS?
Believe it or not, that tape job with diode is factory. Mine is like that. They all are like that. So leave that alone it isn't the problem. You can buy some of the 3 abs relays form TLD aka The Last Detail if you end up needing one, or used from a corvette salvage yard. You need to PM Agent86 for a PDF copy of the ABS section of the GM shop manual and do the diagnosis charts to know the problem. Otherwise you are only guessing and throwing money at the problem. The relays are usually not the problem. You need further diagnosing.
Mike, I couldn't remember where the underscore was in your name or I would have linked to some of your posts. Good stuff! They even come up on a google search
