ignition module went out again
Old May 17, 2007 | 07:05 PM
ChickMagnet's Avatar
ChickMagnet
Default ignition module went out again
It's been about 4 months or so since I replaced the ignition module, now the car won't start again and I know it's the ignition module. Is this because I did not change the ignition coil at the same time? I'm about to change both the ignition module and ignition coil this time around and hopefully that will help. The car runs really great and the engine always runs cool, never overheats, etc. So I don't see why it would be a heat issue.
Old May 17, 2007 | 08:18 PM
JAKE's Avatar
JAKE
If it IS the module again, I'd suspect:
Heat failure resulting from not enough GOOP under the module;
Short in the distributor wiring;
Coil and Pick-up Coil not compatible; Accel talks about red/white and red/yellow wires. I was under the impression this would kill the coil or P/U coil though.
Wires to the module incorrectly connected to the module pins.
Jake
Old May 17, 2007 | 08:23 PM
Sprint7677's Avatar
Sprint7677
On the 15th my the engine shut off while driving. The module was replaced, it started but when it warmed up it shut off and would not start again. Replced the coil BINGO! Runs fine now, the coil was shorting out.
Old May 17, 2007 | 08:57 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Had this exact same problem on another car, no ignition when hot. Diagnosis kept pointing to the module, I replaced it 3 times. I even had the coil tested and it worked fine (when cold). Getting a new coil fixed it.
Old May 18, 2007 | 10:16 AM
ChickMagnet
Jake
Well, I'd rule out module connected incorrectly...as I don't see how it would start fine for four months if they were connected incorrectly. Hopefully it's the ignition coil. I always put all the goop that is provided with the ignition module...and I assume that is enough goop. I doubt it's that. Hopefully it's jus tthe coil as there seems to be others that replaced the coil and got it fixed
Old May 18, 2007 | 02:13 PM
JAKE's Avatar
JAKE
What about a short inside the cap?
I've had that bite me in the A** before when spark jumped from the rotor to the tip of a protruding screw.
Jake
Old May 18, 2007 | 02:18 PM
billybonesmusic's Avatar
billybonesmusic
wouldn't be a bad thing to check, or replace the cap.
simple tune-up stuff?
Old May 18, 2007 | 02:32 PM
86PACER's Avatar
86PACER
Old May 18, 2007 | 05:21 PM
JAKE's Avatar
JAKE
Great post, with all the pics.
I should have mentioned it before, but I always recommend testing first THEN, if necessary, buy the needed part(s).
Throwing parts at the problem isn't the way I feel you should go about it. Lots of guys do that - throw parts at the problem - only to find, a few hundred dollars later, none of the replaced parts were the cause.
Funny, too, then they try to rationalize their mistake by saying things like "Well, it was probably time to change the part(s) anyway" or words to that effect.
Just my thoughts and advice.
Jake
To ignition module went out again
