Help with steel fuel lines?
Old May 17, 2007 | 08:31 PM
jslt1's Avatar
jslt1
Default Help with steel fuel lines?
Guys, I dont want to sound stupid but, here goes. I am trying to install My Zex dry kit. It has an inline fuel booster that says you tap into the steel fuel line, I have 2 fuel lines one that looks like it runs into the regulator and the other that runs to the fuel rail. I think I need to tap into the one that goes to the fuel rail but, Not sure? The one that goes to the fuel rail has like a little "disk" plummed into the line. Is this something to keep the fuel from backflowing or something? Should my fuel booster tap in before or after the little "disk"? I will be gratefull for any help
Old May 17, 2007 | 11:46 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
One is fuel in, the other is the return line... your FSM should be able to point you in the right direction.
Old May 18, 2007 | 04:08 AM
rodj's Avatar
rodj
The line nearest the front ( goes to the pass side rail) is the supply side.
This is the one you need to tap to get pump pressure.
I don't see where you tap as being a problem as the whole line is at the same pressure before the regulator.
Old May 18, 2007 | 05:39 PM
jslt1's Avatar
jslt1
Thanks guys,
To Help with steel fuel lines?
