Oil Pump Intermediate Rod Question
I found that it uses a short stub shaft which indexes with the camshaft to operate the oil pump, but does it also use an intermediate rod/shaft -like the L98, BBs?
If it does, is there something 'Special' about it - length, diameter, etc? I did a Google search but came up empty.
Thanks for any help.
Jake
The housing you refer to supports a stub shaft with the cam drive gear in the same position as usual.
http://shbox.com/ci/oil_pump_drive.jpg
http://shbox.com/ci/ci270-1.jpg
Then a intermediate shaft runs the pump
http://shbox.com/1/op_shaft.jpg
From the Golen site;
do not forget to install the oil pump drive connector, this connects the oil pump to the cam gear
It is. The pump drive on the LTx engines is configured in this respect just like the lower half of the conventional SBC distributor. Jake, pick up a hardened shaft from Melling, Moroso or anyone else who makes them. They come with a steel coupler on them that replaces the OEM plastic type. These are very inexpensive and cheap insurance. I think I paid about $8 for my Melling one.
I'll include it in the order I make next week for valve springs, retainers, locks, adjustable pushrod length checker, etc.
Jake
I'm building a LT1 stroker engine and my goal is NOT to canabalize the parts from my exisiting 350 LT1. So, as much as I can, I'm buying new parts for the new engine, or, failing that, parts from other Forum members who have for sale the parts I need.
When I pull my existing engine from my 96 Vette, I plan it to remain in tact, without having removed the intake manifold and/or the oil pan. See what I mean?
In that regard, I will not be re-using my oil pump, pick up or intermediate rod. I plan to use only the sensors from my current 350 engine.
I have already bought and installed a new oil pump (Melling 155HV) and pickup, and, just today, I bought and installed a new intermediate shaft/rod (Melling 155E).
I also bought a new LT4 oil pan, new rear main seal housing, new camshaft retention plate, new timing chain assembly, not T/C cover, etc., etc.
Now I'm in the process opf tracking down a new water pump and new hub/balancer.
Thanks for all the input.
Jake
