okay go car all back together and need to add fluid to trans since it drained out while trans was out of car. the drain is just square but the fill looks like a giant allen wrench.....any clue whet size or a way to get it out?
shane
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Autzone/Kragen sell this size allen driver in a 3-pack with some other hex sizes. It's in their crappy chinese tool section. You'll need a 1/2" ratchet also.
thanks guys. i did a search and it came up with me needing a 14mm.......um &^$#%^&*!!!!! went to sears at 8:55 and they only had 12 and 17mm.....left and called larry. he said man you need a 17mm.....f**k!!!!! they had that and i didn't get it. so i go to pep boys they standing at the door..."we closed" so call three auto zones per larry and track done the above mentioned 3 piece set 45 miles out...lol...this is getting good! well oil is in and car is done but i guess the slave still needs bleeding as it wont go into gear.....finish it tommorow
I started with a cheapo 17mm from a parts store. It was just a little bit too small, and started to round out the plug on my ZF. I immediately quit and waited until I could find a good quality part. I got mine from Snap On. It has a big, beefy hex in a socket, and works great.
I would suggest finding a good hex before you start this job.
