Having coolant temp. problems need help
Old May 19, 2007 | 05:05 PM
FL87Z52's Avatar
FL87Z52
Default Having coolant temp. problems need help
I have noticed that my coolant will heat up to about 200 with in about 10 minutes of driving it doesn't over heat it just never got that hot that fast. I have recently installed a 2300 torque converter I also added a trans cooler could this cause it heat up from the cooler? The car is a 87 L98. What can cause this or do I need to get lower fan temp sensors. The radiator, water pump and thermostat are all under six months old.
Old May 19, 2007 | 05:52 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If it doesn't go much above 200 then it is a GOOD thing for the engine to warm up quick. That's why you have a thermostat.
