lt1 help
Old May 19, 2007 | 05:13 PM
excessive81's Avatar
excessive81
Default lt1 help
i have been helping my brother install a new cranck in his lt1. the one thing i didn't help was the crank install. we got the motor and trans back in the car today. the problem is he didn't install the piolet bushing in the end of the crank. my question is will this hurt anything? hate to have to tear the trans back out if no really need to. so what you guys think?
shane
Old May 19, 2007 | 05:30 PM
bogus's Avatar
bogus
it could harm the transmission input shaft.
Old May 19, 2007 | 06:17 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
You'll waste the input shaft bearing in short order. It's not designed for the unusual side loads it'll encounter with the front of the shaft having such excessive movement out of it's normal rotational axis.
Old May 19, 2007 | 07:15 PM
AZ Z51's Avatar
AZ Z51
St. Jude Donor '05
If you don't have a pilot bushing the input shaft will wobble instead of spin ,this will most definitly destroy your trans .
Old May 19, 2007 | 09:25 PM
TOMS93's Avatar
TOMS93
Pull out the trans and install the pilot bearing. Otherwise, it will cost 100 x more in the long run.
To lt1 help
