Carb LT4
Old May 22, 2007 | 05:52 AM
vstol's Avatar
vstol
Default Carb LT4
Anyone running a Carburated LT4, I remember seeing an article on this a few yrs back. I have a LT 4 in my 64 GS and would like to get the nostalgia look back, Any ideas
Old May 22, 2007 | 07:59 AM
Z06_BluByU's Avatar
Z06_BluByU
I'm interested in buying your stock intake manifold if you go the carb route!
Old May 22, 2007 | 08:37 AM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Kevin,
I have an Edelbrock LT4 4 barrel manifold I purchased from GM 2 years ago for doing engine dynos and it has been machine match ported to AFR 195 LT4 heads. It has about 5 hours of dyno time on it. Looks like new. PM if interested.
Rick
Old May 22, 2007 | 09:04 AM
Shrek's Avatar
Shrek
I'm in the process of doing the same thing on my stroked LT4 race motor. I'll be using a GM intake, ??? race carb, and firing it through an MSD dist, digital 6 box, with a crank trigger. The trigger and box are transferring over from the injection setup. I'll be ordering the intake, carb, and dist within the next 2 weeks.
Jeff
Old May 22, 2007 | 01:08 PM
Mojave's Avatar
Mojave
What are you going to do for an intake? As far as I know, there is no LT4 specific carb intake, and I don't believe an LT1 or SBC intake will fit the taller port heads without some help.
I can't imagine why you would want to do an LT4 carb motor. The stock fuel injection can be programmed to handle just about anything, and the stock LT4 manifold is pretty good, unlike an L98 intake manifold.
**DISCLAIMER: I don't mean to start another carb/FI war, I'm just curious as to your reasoning. DISCLAIMER**
Old May 22, 2007 | 01:49 PM
PDQUIK95's Avatar
PDQUIK95
Keith,
Here are the GM performance part numbers for LT1 and LT4 Dual plane 4-barrel manifolds if interested. Google on GM performance parts manifolds and you can find various sites with pictures of each.The LT4 has a nice Bowtie logo cast on the front of it like the one I have.
GM #24502592 LT1
GM #24502574 LT4
Rick
Old May 22, 2007 | 02:40 PM
comp's Avatar
comp
Old May 22, 2007 | 07:36 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Originally Posted by PDQUIK95
Keith,
GM #24502592 LT1
GM #24502574 LT4
Rick
I know a couple of people running them too.
Here's a guy running at the National autocross
Old May 22, 2007 | 09:16 PM
vstol's Avatar
vstol
-I will continue to do my homework, if I find the right set up you will have first rights on the intake and throttle body.
-Reason for the switch is stated in my first post.
-Shrek I would like to know more about switching over.
- PD if I switch I will give you a call.
Old May 23, 2007 | 12:42 AM
bogus's Avatar
bogus
my only thought... if you drive this car a lot, I would think that the EFI is the way to go. It will provide you with 30mpg, and the carb will cause a loss... just something to consider with gas prices as they are.
Old May 23, 2007 | 07:37 AM
Z06_BluByU's Avatar
Z06_BluByU
[QUOTE=vstol;1560359540]-I will continue to do my homework, if I find the right set up you will have first rights on the intake and throttle body.
thx
Old May 23, 2007 | 09:42 PM
MSR's Avatar
MSR
anyone know what kind of air filter that is? thanks.
-michael
Old Jun 27, 2007 | 12:14 PM
81ProStreet's Avatar
81ProStreet
7th Gear
Default Carbed LT4
I have built a LT4 with carb to go into my 81 Vette. The chassis is not completed so the motor is not installed yet. Car is being set up with a ZF 6 speed. Pictures availiable at www.dalesvettes.com click on 1981 ProStreet for details of engine build and chassis work.
Old Jun 27, 2007 | 12:46 PM
NitrousSam's Avatar
NitrousSam
Neat project
Old Jun 27, 2007 | 02:07 PM
BrianCunningham
-michael
No, but PM me and I'll give you his email.
Old Jun 28, 2007 | 05:46 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
LT4 Dual plane 4-barrel manifold dosen't make as much hp as the single
plane.At the time I installed mine ,GM was the only one for the LT4 engine so I have that with the AFR 220 heads.
Jegs has the aircleaner that will fit under the hood if you are going to continue in that dirrection.
I run an 850 holley 94 in the primary and 96 in the secondaries with vaccum secondaries,msd 6al box with an electric choke.
If you are going to stay stock I would leave the fuel injection.
You will have to run an electric water pump and get the GM block off that fits into the timing cover.The change is no big deal .What info do you need?
Old Nov 18, 2011 | 08:25 AM
Donnie60's Avatar
Donnie60
6th Gear
Default how
Kevin,
Rick
How much do you want for it? deyoung@tds.net
To Carb LT4
Old Nov 18, 2011 | 08:27 AM
Donnie60's Avatar
Donnie60
6th Gear
I have a 1984 corvette and I want to put lt1 -lt4 heads on it, I am looking for an intake for it carb please. deyoung@tds.net
Old Nov 18, 2011 | 09:20 AM
96GS#007's Avatar
96GS#007
4+ year old thread. I wouldn't count on getting a response. Your best bet is to post a NEW "Want to Buy" (WTB) thread over in the Parts For Sale section of the Forum.
Old Nov 18, 2011 | 09:48 AM
cv67's Avatar
cv67
St. Jude Donor '05
Good luck getting those heads to work on your Gen1 motor. (they wont!)
Lot easier to put a Gen 1 head carb/intake on it.
Nice work on the search function btw
