#2 plug carbonized
Old Oct 22, 2001 | 10:01 PM
2-Vettes's Avatar
2-Vettes
Default #2 plug carbonized
My '92 started missing Sunday evening. Had it at the shop today and the guy said the #2 spark plug was carbonized possibly with oil. He put in a new plug and checked the others. All else was ok.
And the significance of this would be???? Linda
Old Oct 22, 2001 | 11:49 PM
bogus's Avatar
bogus
Default Re: #2 plug carbonized (LT1)
you have a cylinder going down... so to speak.
the cylinder my have a bad valve seal, valve guide or even a ring collapsed.
it could be as simple as a bad injector flooding a bit too much fuel into that cylinder, too.
however, this could get expensive.
[Modified by bogus, 9:50 PM 10/22/2001]
Old Oct 23, 2001 | 12:24 AM
Muskrat's Avatar
Muskrat
or it could just have been a bad plug. always start with the simple things first.
Old Oct 23, 2001 | 03:45 PM
SunCr's Avatar
SunCr
How many miles since the plugs were changed? Dry carbon is usually fuel; wet oil. Pull it again after a couple hundred of miles and see what it looks like. Otherwise, do a balance test on the injectors and ask the mechanic if he checked the resistance of your plug wires.
Old Oct 23, 2001 | 07:51 PM
2-Vettes's Avatar
2-Vettes
Default Re: #2 plug carbonized (SunCr)
18K miles on the plugs and wires. I'll keep a close eye on it.
Thanks everyone for your responses. I always know I'll get some input from you all when I have a question Linda
To #2 plug carbonized
