Is this Bad?
Old May 22, 2007 | 08:26 PM
hippy's Avatar
hippy
Default Is this Bad?
I was told this piece was probably not working correctly and was wondering if anyone knows what it is and if that is correct?
The car is a 90 and an auto.
Old May 22, 2007 | 08:45 PM
etown brawler's Avatar
etown brawler
what part is it out of?
Old May 22, 2007 | 08:49 PM
CFI-EFI's Avatar
CFI-EFI
The picture is too out of focus and blurry, to even identify what it is, but even I can tell it isn't working, unless it's sole purpose is as a paper weight.
RACE ON!!!
Old May 22, 2007 | 08:52 PM
SCCA VETTE's Avatar
SCCA VETTE
isnt that the part that the input shaft is suspose to be connected to? I cant recall the name of it, but I think it is suspose to have a shaft off the end and the part that we see goes into the center of the clutch pack. JUST A GUESS!!
Old May 22, 2007 | 08:55 PM
hippy's Avatar
hippy
RACE ON!!!
It isn't THAT out of focus. I took that picture 5 times and everytime I hit the button it went out. This was the best one.
It's actually part of the trans and I believe it would be the outer race to the forward input sprag. I thought I puked the sprag but I killed this little beauty instead.
Old May 22, 2007 | 09:13 PM
95BLKVette's Avatar
95BLKVette
You ripped the inner shear lugs off the overrun clutch pack inner shell that connects it to the forward sprag assembly
Guess your forward clutches were toast, so the overrun clutches took over...this clutch pack only engages when you are manual shifting 1-3 ......I assume you were getting on it pretty hard, or else just using manual shifting because you forward clutches were fried and this is the only way you could get it to move.....
Old May 22, 2007 | 09:16 PM
Scott-89's Avatar
Scott-89
Try the Macro setting on your camera for close up shots.
Old May 22, 2007 | 09:27 PM
hippy's Avatar
hippy
ACTUALLY, I beat the **** out of the car on a regular basis (all legal per CFOT rules) BUT...I was going to work last October and coming down a hill to a stop sign. I was only going 55-60 and I shifted into 3rd gear to get a little engine braking, then hit 2nd gear around 35-40 and POP. So it wasn't used to me being nice to it. NEVER again will that car see any sympathy from me (all legal per CFOT rules.)
The trans worked fine before and after it dumped this out except the lack of the manual downshifts (I could manually downshift just had to get the rpms up the catch up due to the lack of the forward input working proper) after the pop. The clutches were fine, the 3-4 showed a little burnage (probably from the over 5000 rpm shifts) but everything else in the trans is pretty much OK.
Old May 22, 2007 | 09:38 PM
mseven's Avatar
mseven
A 1990 OEM ashtray from eckler's?
already breakin' $heet I see and the season barely started
Old May 22, 2007 | 09:52 PM
hippy's Avatar
hippy
Actually that is 2006 breakage. I hope the new trans holds for 450-500hp. I am not too worried about the torque due to the fact I run a Miniram and EVERYONE and their mommy on the CFC4T KNOWS that Minirammed cars don't make torque, right Mick?
Old May 22, 2007 | 10:10 PM
mseven's Avatar
mseven
yeah the torqueless monster.. I was just thinkin I could use more wheel spin...et's don't seem to suffer
I thought you were gettin out this way this year/century??
Old May 22, 2007 | 10:22 PM
hippy's Avatar
hippy
I didn't make it out for my bike cruise last year. My mommy wouldn't sign my permission slip.
To be honest I don't remember why I didn't make it.
Old May 22, 2007 | 10:27 PM
mseven's Avatar
mseven
maybe she didn't sign because the pooch needs to be over 50cc for highway driving?
Old May 22, 2007 | 10:36 PM
hippy's Avatar
hippy
It may only be 49cc but I did manage 44.3mph out of it last year after a bit of modding. I now have a Puch with a fart pipe and a bored out carb and intake and no head gasket. No kidding either.
Old May 22, 2007 | 10:42 PM
mseven's Avatar
mseven
remove frisbee, a.foil...how's the real/big scooter runnin?
Old May 22, 2007 | 10:47 PM
AKS Racing's Avatar
AKS Racing
I actually picked up torque with the MRII over the old SR, but it may have had something to do with moving from a D1 to a D1R. Hmmmm...
Aaron
Old May 22, 2007 | 10:53 PM
hippy's Avatar
hippy
The big scoot is running very well. I have over 8000 on it. Very fun to drive yet. At least having that will keep the miles down on the vette this year again. Gotta have a CD player to keep me interested in driving motorcycle and so far it's working.
AKS, I said that tongue in cheek about the torque. All the dipshts here that have only read about them and have no first hand knowledge are the ones I am mocking.
Old May 22, 2007 | 11:00 PM
AKS Racing's Avatar
AKS Racing
Not an issue. I since switched to the C4SP. And at the same time switched to a Mustang Dyno vs the previous Dynojet runs. And then I had to go and over double the boost (recorded over 25 psi at 6100RPM).
There is no need for this much power on the street.
Aaron
Old May 22, 2007 | 11:32 PM
mseven's Avatar
mseven
Originally Posted by AKS Racing
There is no need for this much power on the street.Aaron
the only down to big power is the lack of bite /hook..so the no.s are getting real big these days
To Is this Bad?
