My new DeWitt's Radiator...
Old May 31, 2007 | 10:57 AM
  #41
LD85's Avatar
LD85
Hey I bought Serial # 0001 and I didnt get a sticker
but I did meet Jim at the Funfest a couple of years back, he's a super nice guy!
Old May 31, 2007 | 11:58 AM
  #42
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Originally Posted by LD85
Hey Tom, could a person run lines from your tranny cooler to the factory watter fittings on the factory Oil Cooler ?
Would it be better than running the coolant lines to the oil cooler from the water pump?
Huh? What? I don't understand
Old May 31, 2007 | 12:01 PM
  #43
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Originally Posted by bogus
I like a couple to put on my tool box... it reminds me what all I have added over the years!!!
You should have gotten one of the new silver ones on top of the radiator. No?
If not, we can mail anyone that wants them a sticker or two. We have small shiney foil ones 1" x 4" or larger bumper stickers (black on white) about 3" x 9" or so.
Email Christyn@dewitts.com with a mailing address and we'll send them to anyone
Old May 31, 2007 | 01:43 PM
  #44
billybonesmusic's Avatar
billybonesmusic
i am really close to getting mine!! my fender strat didnt sell for some reason, so now i have to get the money somewhere else
i would like a tranny cooler/oil cooler model !! with sticker of course,,
Old May 31, 2007 | 03:26 PM
  #45
ScaryFast's Avatar
ScaryFast
I don't think there is a version with both, either the Auto trans version with trans cooler or 6-speed with or without EOC. Tom, correct me if I'm wrong.
Old May 31, 2007 | 04:28 PM
  #46
bogus's Avatar
bogus
oh, yea, there is a shiny nice foil one on the radiator itself... but that is already stuck there! and once the shrouding is all installed, it can't be seen!!
I will admit, I am being petty and childish... the radiator itself is a real work of art. It arrived PERFECT. The packaging is very well thought out and exceptionally effective.
Old May 31, 2007 | 04:29 PM
  #47
bogus's Avatar
bogus
Originally Posted by CentralCoaster
EBJ is all cholesterol, all the time. We should get some EBJ stickers for our vettes.
that would rock.
Old May 31, 2007 | 04:36 PM
  #48
ScaryFast's Avatar
ScaryFast
Did you slice your thumb open like Rick did during his install?
Old May 31, 2007 | 05:27 PM
  #49
cv67's Avatar
cv67
St. Jude Donor '05
To bad its going to be covered up by a fan shroud. If you want that sucker polished, lemme know.
Old May 31, 2007 | 06:23 PM
  #50
rickneworleansla's Avatar
rickneworleansla
Hey, the job's not done right until a little blood is spilled.
Old May 31, 2007 | 09:37 PM
  #51
bogus's Avatar
bogus
blood spilled is a rite of passage.
Old May 31, 2007 | 10:02 PM
  #52
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
That would accomplish nothing since the oil cooler lines have coolant in them, not oil. Plus you need something to circulate the fluid. Now if you had an oil filter relocation kit, then you could accomplish something, using the oil pump to push oil through the radiator side tank.
Old May 31, 2007 | 10:04 PM
  #53
CentralCoaster
They should make them out of soft plastic so as to prevent that. Or perhaps come shipped with a miniature mechanic to install it for you.
Old May 31, 2007 | 10:13 PM
  #54
cv67's Avatar
cv67
St. Jude Donor '05
I had heard they dont recommend running oil or power steering fluid through the radiator side tank (to use it as a cooler) for some reason, maybe Tom can give us some input.
Old May 31, 2007 | 10:14 PM
  #55
CentralCoaster
I asked him that already. I forget the answer. Maybe it's too restrictive.
Old Jun 1, 2007 | 08:00 AM
  #56
LD85's Avatar
LD85
This was one of those "what if" deals for me,,, I was looking for a way to cool the oil better without using the same water that flows thru the entire engine in hopes that the oil could be cooled more efficiently with the radiator I already have,, instead of adding an oil cooler rad, which would be a really tight fit to mount. I realize that it has to be circulated by a pump of some sort, I could figure that out.
So in essence,, nevermind.... I'll go back to sleep
Old Jun 1, 2007 | 11:51 AM
  #57
C4DC's Avatar
C4DC
St. Jude Donor '06
I think I remember Tom stating that the design wasn't sufficient for oil cooler use. Something to do with the size of the fittings being too small or the pressure being too much. It would be a very cool product if he were able to incorporate a true oil cooler/warmer into the radiator. There is a lot of discussion about high oil temps over in the autocross/roadrace section. It would be one less thing to have to mount seperately under the car. :
To My new DeWitt's Radiator...
Old Jun 1, 2007 | 01:37 PM
  #58
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Exactly! The trans oil Coolers (toc) have a much higher pressure drop that a cooler designed for Engine oil cooling (EOC). This is why you see people insisting they need 5/8" or even 3/4" hoses for these packages when the oil flow from the engine is only 2-4 gpm. You could handle that volume of oil with 1/2" lines but they got so much pressure drop from the oil cooler they are trying all kinds of things to reduce it and the pressure drop is not the hoses anyway.
Old Jun 1, 2007 | 01:45 PM
  #59
ScaryFast's Avatar
ScaryFast
LD, just mount an external cooler to the front of the radiator. There's plenty of air flow for both.
If you need pics let me know.
Old Jun 1, 2007 | 01:56 PM
  #60
Aardwolf's Avatar
Aardwolf
I was thinking of that to. I already have a trans. cooler there. Plus I'd like a PS cooler to, are you running one? A combo cooler is looking good. I wonder if one of the frame rail EOC would help at all. They are long and thin with fins. Maybe putting one in each line from the stock oil warmer would help. They could mount to the bottem of the car and not take up space in front. (some place safe on the bottem though!)
