what do you think?
Old May 24, 2007 | 12:42 AM
MexCareBear's Avatar
MexCareBear
Default what do you think?
well im going to install headers in about a month or so...well i was wondering what kind should i go with?...whats everyones favorite?...i was thinking hooker long tubes?...plus what about that a.i.r system...if i get headers...what then will i have to do with that thing?...help anyone?
Old May 24, 2007 | 12:49 AM
evmlarry's Avatar
evmlarry
Rip it out... you already pulled your cat anyways, right?
The smog pump is kind of rendered useless then.
Of course, it already is kinda useless as it is.
Old May 24, 2007 | 12:55 AM
MexCareBear
well...noo i havent, i still have the stock exhuast manis and also the cats...but i have true dual an magnaflows...but i was wondering what headers. and what do i just do?...how can i just "rip" it out?
Old May 24, 2007 | 12:58 AM
evmlarry's Avatar
evmlarry
I can't speak to headers...
But for the smog pump... just pull the pump and put the delete bracket in there. Many places sell one.
Or since the pump is free turning, you can just leave that on. But you can remove the plumbing for it and also remove the solenoid and diverter.
Once that's out you're done. Just tie up the plugs. You won't throw any codes.
If you don't get headers, you can either cap off the tube or cut off the tube and have someone weld it.
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If you have smog visual inspections you need headers with air tubes to keep your smog pump functional. If you live in CA, you can't do the headers at all.
If none of the above, get ones with no air tubes. But not all of these come with bungholes for the oxygen sensor, which you will need.
Old May 24, 2007 | 01:02 AM
MexCareBear
now since were talking about it...when i get the headers(long tube) and does have the o2 sensor holes, and i dont have the cats where can i get the sensors for it or whatever?...and if do stick wit the cats...im putting high flow cats and would i still have to put the o2 sensors behind the cats?
Old May 24, 2007 | 01:08 AM
CentralCoaster
The o2 sensors behind the cats, if any, are probably only there to throw codes for dead cats or to control the emissions systems.
The ones in front of the cats are used to control your mixture.
You can use the same upstream ones as you have now, if anything they'll take a little longer to warm up and reach closed loop.
Old May 24, 2007 | 01:18 AM
MexCareBear
so pretty much just have the long tubes screw the o2's pretty much where they are in place NOW on to the headers?
Old May 24, 2007 | 01:22 AM
CentralCoaster
No, you either put them in the collector, or in the Y pipe after that if you don't want to eff up a ceramic coating.
Hooker puts it in the #7 primary which is a pretty crappy idea IMO, tuning the whole car based on the richest cylinder.
Old May 24, 2007 | 01:24 AM
MexCareBear
ohh alrite..well mines true dual an dont have a y pipe..
Old May 24, 2007 | 01:28 AM
CentralCoaster
In that case install it in your left ear.
Old May 24, 2007 | 01:30 AM
MexCareBear
lol alright...and one up your *** also
Old May 24, 2007 | 01:34 AM
cv67's Avatar
cv67
St. Jude Donor '05
perfect.
Old May 24, 2007 | 01:44 AM
CentralCoaster
My bung hole is ceramic coated.
Old May 24, 2007 | 01:46 AM
cv67's Avatar
cv67
St. Jude Donor '05
prove it.
Old May 24, 2007 | 01:52 AM
evmlarry's Avatar
evmlarry
To what do you think?
