700r4 with Shift Kit TV setup
Old May 24, 2007 | 02:29 AM
TPI84GMC's Avatar
TPI84GMC
Default 700r4 with Shift Kit TV setup
Should the TV cable setup be the same in a trans with a shift kit or do the shift speeds change? Installing a rebuilt trans with b&m shift kit installed.
Old May 24, 2007 | 02:46 AM
Scott-89's Avatar
Scott-89
I had a Trans Go shift kit installed in my 89 and the TV cable wasn't changed at all.
Old May 24, 2007 | 03:03 AM
rodj's Avatar
rodj
Old May 24, 2007 | 09:42 AM
Aardwolf's Avatar
Aardwolf
The govenor weights change the shift RPM, not the TV cable. When I installed my shift kit, I did do the TV cable adjustment when I was done.
To 700r4 with Shift Kit TV setup
