Would Like My Fan Temps Programmed
Old May 25, 2007 | 07:18 AM
1blkc4's Avatar
1blkc4
Default Would Like My Fan Temps Programmed
I Would Like To Get My Fan Temps Lowered On My 94 Anybody Do It In The Cleveland Oh That Is Reasonable??
Old May 25, 2007 | 07:33 AM
corvette-pilot's Avatar
corvette-pilot
Bought a cheap Hypertech off ebay to do mine
Old May 25, 2007 | 09:18 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Mate if you have a laptop and Tunercat with the EE definition file, you can send me the .bin file and ill set them to what ever you like for free.
Old May 25, 2007 | 02:55 PM
1blkc4's Avatar
1blkc4
i have nothing
Old May 26, 2007 | 09:49 AM
Casethecorvetteman
Well mate i cant help ya!! If you had the laptop and the program i could. Bit far from Australia to OH!!!
Old May 27, 2007 | 11:22 AM
jmalez's Avatar
jmalez
Default Ned info on tuner cats fan temp setting
Where do you go in tuner cats to set temp settings for fan on and fan off, I see the setting for oil temp but not coolant temp my ignorance I know but any help will be apreaciated thanks
1995 lt1 corvette
Old May 28, 2007 | 02:40 AM
Casethecorvetteman
Have a look here mate:
The RED is for Fan 1
The GREEN is for Fan 2
The PURPLE is how many degrees C the coolant temp has to go down from the fan on temp before the fans shut off
The BLUE is the vehicle speed in MPH that must be reached for the HIGH SPEED fan settings are used, until you reach this speed, the ECM will use the LOW SPEED fan settings.
Old May 28, 2007 | 07:37 AM
jmalez's Avatar
jmalez
Thanks that helps very much, turns out that i was using ECM_EE.bin that do not have the fan controls on them but when i loaded ECM_EEB there they were, thanks again !!!!!!!
Old May 28, 2007 | 08:40 AM
Casethecorvetteman
get the updated .EE definition file mate, dont use the .EEB
Old May 28, 2007 | 09:22 AM
jmalez's Avatar
jmalez
ok,, I just purchased these definitions about 2 months ago from the tuner cat web site and they came with ee and eeb . is there somewhere else that has these files and what is the difference between ee and eeb, i am thinking eeb must be beta ?
Old May 28, 2007 | 09:35 AM
Casethecorvetteman
Nah mate they should be both the same, its just that your car being 95 it should be using .EE, if you only got them 2 months ago you should have the latest file, so im not sure whats going on there.
Old Jun 10, 2007 | 07:37 AM
bob-05's Avatar
bob-05
The CF version of PCM_EE moved the " FAN enable VS coolant temp" out from the constant table to the regular table. It is about half way through the list of tables.
Old Jul 23, 2007 | 11:01 PM
brianwetzel's Avatar
brianwetzel
I just started using Tuner Cats EEB file and it is the CF version. I do not see the fan temps anywhere. I see the settings for oil temp but not for coolant temp. I also do not see an "fan enable VS coolant temp" but I do see a "fan enable coolant temp VS speed". Is that the one to use?
Thanks in advance, Brian.
Old Jul 23, 2007 | 11:31 PM
brianwetzel
Another interesting thing is the file I downloaded from my 95 has 0 for the setting "Fan Threshold High Speed (MPH). Is that normal from the factory?
Old Jul 24, 2007 | 11:29 PM
brianwetzel
Anyone? I am not sure if I should just change the fan temps lower or also add a number to the "Fan Threshold High Speed (MPH)". It makes sense it should have a speed set but why does the factory one not? Also, does it matter if I save the factory file as a .bin or .lt1 and will either work for loading back? I am using TunerCat and want to make sure I do not screw up my ECM setting the fans lower.
Thanks in advance.
Old Jul 25, 2007 | 03:21 AM
STL94LT1's Avatar
STL94LT1
Yes
Old Jul 31, 2007 | 01:08 AM
brianwetzel
Well, I did my first CATS PCM program and it worked without a problem. I lowered the fan on temps and added a speed for the high threshold. It has always made me wonder why GM has the fans come on right away when using the AC but wait so long to turn them on when the AC is off. I had this issue with my 88 GTA and my 88 Vette and installed a manual switch for them both. I have to say I am impressed with being able to program the ECM on the 95 so easily and might look at some other settings now as well.
To Would Like My Fan Temps Programmed
