Header gaskets
Old May 25, 2007 | 02:42 PM
carriker's Avatar
carriker
Default Header gaskets
I bought some Hooker 2151 headers for my LT1. What gaskets do you guys recommend for these headers?
Another questions. The gaskets that summit says I need for an LT1 are D-port gaskets. The headers aren't d-port, they are rectangular. Is this right? Thanks.
-Matt
Old May 25, 2007 | 03:24 PM
STL94LT1's Avatar
STL94LT1
Your heads are D-port, you need D-port gaskets. I like the Percy's Seal-4-Good aluminum header gaskets, part # 66031.
Old May 25, 2007 | 04:47 PM
carriker's Avatar
carriker
But it's ok that the headers are rectangle?
Old May 25, 2007 | 05:00 PM
CFI-EFI's Avatar
CFI-EFI
You are right. The gasket only seals between the metal of the head and the metal of the header flange. A "D" shaped gasket, if anyone makes one, is a wasted effort. All a "D" port shaped gasket would do is leave gasket material heat up, burn off, and choke the header tubes with ash and residue.
A lot of people spend horrendous amounts of money on gaskets and fasteners. If you will rake the tome to re-tighten your header bolts after the first few heat cycles, you will find that any decent gasket will work well. Didn't the headers come with gaskets?
RACE ON!!!
Old May 25, 2007 | 07:29 PM
jimmers's Avatar
jimmers
The headers should come with the gaskets.
Old May 25, 2007 | 07:43 PM
aboatguy's Avatar
aboatguy
RACE ON!!!
I disagree this time. Thirty bucks for a good header gasket is money well spent.
My Percy's Dead soft aluminum header gaskets are LT1 specific D-ports and they didn't burn up, don't leak, have been reused numerous times. Did I mention they don't leak.
My car was used during extreme conditions IE -20 degrees fahrenheit in the winter and 100 plus in the summer without a header leak, I'd buy/ will buy Percy's again (Who knows I may goon them up on the next install) In the past I'd have to replace header gaskets at least once a year and I've always tried to re-tighten the header bolts.
Mike
Old May 25, 2007 | 07:44 PM
STL94LT1's Avatar
STL94LT1
Old May 25, 2007 | 08:14 PM
carriker's Avatar
carriker
I didn't buy the headers from a company, I bought them from an individual and he didn't have the gaskets.
Old May 25, 2007 | 08:17 PM
carriker's Avatar
carriker
By the way, what size reducers do I need to get. 3 inch to 2.75 inch? I think that my pipes are 2.75 right? Is that a hard reducer to find at an autoparts store like NAPA, Autozone etc?
Old May 25, 2007 | 08:23 PM
CFI-EFI's Avatar
CFI-EFI
Mike
I'm not saying the expensive gaskets are no good, I'm saying they are unnecessary. A good Fel Pro or Mr Gasket gasket can do as good a job for half, or less the price. So Mr. Percy's gaskets have "D" ports, eh? Explain the advantage of having gasket covering an area of the head that isn't backed up by header flange. I DO concede that an aluminum gasket won't burn up. I have had cheap conventional header gaskets last for years, until the next tear down.
RACE ON!!!
Old May 25, 2007 | 08:32 PM
STL94LT1's Avatar
STL94LT1
You'll also need to get the front tubes on your cat-back narrowed to fit the headers. I had my cat-back altered and reducers made at Midas.
Old May 25, 2007 | 08:45 PM
Aardwolf's Avatar
Aardwolf
I know Summit and Jegs to I think, have reducers, they are kind of expensive though.
Old May 25, 2007 | 09:09 PM
aboatguy's Avatar
aboatguy
RACE ON!!!
I'm just saying that I've blown out and burned up lots of Mr. Gasket and Fel-Pro header gaskets on other cars over the years and the Percy's have worked fine. I'd rather spend the extra 10 bucks and do it once. As for the D-port they were the same price as the regular SBC gaskets so there was no difference in cost and having a piece of aluminum thats covering another piece of aluminum= no drama.
It seems to me that many people don't have the time/money to do something right. However, they always find the time/money to do it over.
Old May 25, 2007 | 09:23 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Nice line....
Old May 25, 2007 | 09:33 PM
CFI-EFI's Avatar
CFI-EFI
And I have had the same success with conventional gaskets.
I agree. No harm, no foul. Also, no point.
I whole heartedly agree with that. If it weren't for that, the expensive "cure-alls" for the lazy or uninformed wouldn't exist. Properly applied and maintained, the conventional, popularly priced parts, work great. Ineptitude has created a market for the likes of Mr. Percy, Stage 8, etc.
RACE ON!!!
Old May 25, 2007 | 09:59 PM
STL94LT1's Avatar
STL94LT1
RACE ON!!!
WOW!!! Now please explain to me why so many missed this guy?
Old May 25, 2007 | 11:02 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I didnt miss it. I have used two recently. Earls Pressure gaskets. Never had a leak. And I used factory gaskets that come from GM for the stock exhaust manifolds and no leaks. I used the OEM stuff for a fix/check I was doing.
One thing that is really important for gasket sealing properly is torque of the bolts, and how well the header is made, with thickness of flange, flatness being very important. My DRM headers are very good quality, and I think almost any gasket can work well with no leaks. I also have my heads with timecerts (similiar to helicoil(which LPE does too)), so the bolts are going into steel vice aluminum, and they dont back out over time.
So, my 2 cents here.
To Header gaskets
Old May 25, 2007 | 11:30 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I use Percy's on both of my vehicles because it's the best header gasket.
If you want to save $15 and increase your chances of gasket failure, have at it.
Also, Percy's are reusable and not a bitch to remove. Ever try scraping a steel reinforced composite gasket off of an aluminum head?
Old May 26, 2007 | 12:05 AM
C4DC's Avatar
C4DC
St. Jude Donor '06
I'll second the Percy's...
Old May 26, 2007 | 01:12 PM
BlackHarleyMan's Avatar
BlackHarleyMan
I also just put LT Coated Hookers, Hooker Front Y-Pipe, High flow Cat, and brand new Cat-back on my 91. I used the Percy's Dead soft SBC Square header gasket #66012, and the Dead Soft Alum 3" collectors. I still have to retighten everything, but I'm very happy with it so far! The next adventure is to duplicate this effort for my LT-4.
