Ecklers fan kit confusion..
I am slightly confused by the 'apparently' easy directions that come with this kit... I got the kit with the sensor that goes in the drivers side head between 1 and 3 and has a 2 wire 'harness'
I had previously put a 180 stat in the car and now I want to add the kit..I got the one that turns on the fan at 195 but according to the directions my cars main fan is turned on by the ECM.. and the kit turns on the aux fan?
(Yes, my car has the aux fan according to the RPO codes)
Is there a way to wire this so the main fan turns on at 195 instead of 226 (or thereabouts)?
Cruising down the highway the car runs just over 180 but in traffic on a 90 degree day it climbs right up till the fan kicks on.. I'd like the fan to kick on sooner so I'm hoprful this kit will do the trick but it's late, my brain is tired from hours of reassembly and I really want to add coolant and get this thing fired up tomorrow.. (just replaced head gaskets)
Thanks,
By cutting the switch you have, into the line to the ECM the new switch will turn on (earth out ) the fans at the set temp.
The ECM will still turn on the fans if the switch fails.
As vinnies87 said , has been well documented here.
Not sure about the "2 wires" .Early models only had 1 wire to the switch which only controlled the 2nd fan.
What I had to do with the kit was use a splice to hook it up to the main fan relay-one of the wires from the harness- its under or near the brake booster area and then run the kit wire to the back up fan relay near the hood up front and splice in.
Basically,youre taking the signal from the main fan and passing it along to the back up fan so it activates the same time.So it makes both fans come on the same time.
The kit gave me a a small plastic splice to crimp on the signal wire on the main fan relay and attach it to the back up relay up front.Does this help any?
The back up fan wont come on until the car overheats,and running both fans,albeit noisy,really does bring down the temps under there during HOT summer days.
Hope this helps some.I think I got my kit from MAD vettes years ago.
Wish I could remember it word for word.
Thanks,
You will need a 22mm socket and a pan to catch about 3 quarts of coolant when you pull that sensor. Also use anti sieze when you put it back in.
This is what I did, and my main fan has yet to come on this year except with the AC on.
BTW you won't need the wirig harness, just use the existing plug.
Seriously?
Just plug the existing single wire connector into the new sensor? easy as that?
That just seems to easy
( and nothing ever is for me
)Can I make sure the aux fan works by grounding that single wire that attaches to the sensor? or is it not that easy?
edit: This first picture shows the sensor in the radiator.. Is that the coolant temp sensor for the display on the dash? or is this the one that reports to the ECM so the main fans can be turned on?
This next picture is of the new sensor from the Ecklers kit installed in the drivers head.. I used the new plug since the old one had broken plastics. I just spliced the 2 wires coming out of the new plug together and then joined them to the original wire that went to the old sensor.. it was a green wire with a white stripe.
and this last one of the 2 relays up next to the brake cylinder on the inner fenderwell... Is it safe to assume these are the fan control relays for the main and aux fans? (If the old wiring hooked up to the new sensor doesn't work, This is where I can run the new 'harness' wires to?)
Thanks~
RACE ON!!!
RACE ON!!!
Head gasket job is done.. and the fan kit works fine.
At first the car wouldn't start.. Did you know that you need 8 wires attached to the spark plugs, not just 4??
completely forgot the passenger side before trying the key
Once the car was running I got some smoke under the hood from stuff burning off the exhaust, but the car is running smoothly with no apparent leaks. Throttle response is good, even the coolant has stayed full since I was able to fill the system through the thermostat opening.
Once the temp hit 199 the aux fan kicked on and the car stayed right at 196 - 200 for 5 minutes until I shut it down.
After the kids go to bed I'll put the front tires back on and take it off the jack stands and take it for a spin.. Can't wait to drive it again instead of wrench on it ~
