Ccm (body Control Module)
Old May 26, 2007 | 10:14 AM
sneaky pete's Avatar
sneaky pete
Default Ccm (body Control Module)
DEALERSHIP CROSSED OVER CCM#16146688 TO BODY CONTROL #88992228 AND ITS ON MAJOR BACK ORDER.DOES THIS SOUND RIGHT & WHAT TO DO NEXT? TRYING TO GET SIGNAL TO MAKE INJECTORS PULSE.
Old May 26, 2007 | 09:02 PM
-=Jeff=-'s Avatar
-=Jeff=-
what is the symptom of the car? why is the CCM Suspect? Yes I have heard tat certain CCMs are hard to find
Old May 26, 2007 | 10:33 PM
bogus's Avatar
bogus
I'm with Jeff. Why is the CCM at fault here?
Discribe more about the car.
Old May 27, 2007 | 11:01 AM
sneaky pete
Default Problems
90 c4 electrical problems
All started when altenator went out. After replacing altenator, no start. (no power to starter enable relay or fuel enable relay or injector pulse.)
1. By-passed starter relay.
2. Fuel pressure 45 psi.
3. 16 ohms on all injectors.
4. Sparkplugs are firing.
I have no LCD power or injector pulse. Should I replace CCM first or ECM? Without LCD, I can't get any codes.
I REPLACED ECM YESTERDAY ,SAME THING. IS THE CCM THE VATS MODULE OR IS IT A MODULE BY ITS SELF?
Old May 27, 2007 | 01:26 PM
bogus's Avatar
bogus
VATS is built into the CCM. There isn't a separate module. And the VATS won't keep the LCD from lighting up.
I would check the main grounds inside the car. They're located on the inside kick panels - one on each side.
If the CCM is bad, you might want to call Jason at www.vette2vette.com... his website has crashed and I don't have my cell phone handy... sad... I will get the number shortly.
Old May 27, 2007 | 03:19 PM
-=Jeff=-'s Avatar
-=Jeff=-
Originally Posted by bogus
you might want to call Jason at www.vette2vette.com... ... I will get the number shortly.
1-815-673-6200 Vette2vette
I have it programmed in MY cell phone
Old May 27, 2007 | 04:30 PM
RRT vette's Avatar
RRT vette
Read this!
Old May 28, 2007 | 12:28 PM
sneaky pete
Default Thanks
THANKS FOR # JEFF. I WILL GIVE THEM A CALL TUE.
Last edited by sneaky pete; May 28, 2007 at 12:30 PM. Reason: RRT VETTE THAT WANT WORK FOR ME,(CANT FIND WEBSITE)
Old May 28, 2007 | 01:19 PM
bogus's Avatar
bogus
I do to! It's that my phone was in the other room charging...
To Ccm (body Control Module)
