Help Diagnos - P0118. 1996 LT4
Old May 26, 2007 | 04:04 PM
all4c4lt4's Avatar
all4c4lt4
Default Help Diagnos - P0118. 1996 LT4
Hi all,
I pulled my codes today and found a P0118 - Engine Coolant Temp Circuit high input. Is this the code for the sensor itself, and if so, am I able to tell which sensor (front or pass side)? This code appeared after I installed my LT headers. Maybe the wire is charred by the headers somewhere? If not, where should I begin my search?
Both of my cooling fans run constently, I mean from the time I start the car (even when cold) until I shut it off. I don't know what is causing this, but it started when the code appeared.
Also, I have a warm start issue. The car will not start when warm unless I press the gas pedal. Injectors? The car only has 40k miles.
The only other thing that I can think of that may give additional info is that the rear 02 sensors are unplugged due to my high flow cats, but I did not get a code for them. Thanks for any help or ideas!
Old May 26, 2007 | 06:09 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Do you have the FSM? If not, I can scan and email you the pages dealing with the P0118 DTC...
Old May 28, 2007 | 11:51 AM
all4c4lt4's Avatar
all4c4lt4
tobijohn, PM sent with my email.
ttt - anyone know about the hard start and fan issue, or is that related to P0118?
Old May 28, 2007 | 01:06 PM
tobijohn's Avatar
tobijohn
Bench Racer
email sent but in case this comes up again, I'm going to post the pertinent pages from the FSM so if anyone searches the archives, they'll have the info here
Old May 28, 2007 | 05:38 PM
toptechx6's Avatar
toptechx6
I'd guess the code,fan and hard start are all related. Use Tobijohn's trouble shooting chart and fix the trouble code first, good luck.
To Help Diagnos - P0118. 1996 LT4
