Accel Superram
Old May 26, 2007 | 11:53 PM
tonyboo's Avatar
tonyboo
Default Accel Superram
Hi all. i bought a accel super ram sistem for my 85 corvette. the guy that i bought it from had it install in a 73 corvette. he gave me everything wiring harness CPU . my question is does this new wiring harness and cpu replaces everything my old cpu and harness or can i still use the sistem from my tps. i would really apreciate any help.
thanks.
Old May 27, 2007 | 12:26 AM
sami85L98's Avatar
sami85L98
I have SR too and several others here, pretty much everyone has stock ECM, very few gone with Accel DFI, dont know though. I have good luck with my stock 85 870 ECM. U just need to upgrade the chip though, but we need some info from u?
Old May 27, 2007 | 12:39 AM
John A. Marker's Avatar
John A. Marker
You can install the SR on your 85 without any change to your stock chip. The only time you have to change/up grade the chip is if you change cams. The Stock computer can handle the SR without any problems.
Old May 30, 2007 | 03:25 AM
tonyboo's Avatar
tonyboo
hey thanks for the help i am also putting a paxton supercharger on it and the engine just got a swap 383 stroker kit and a brand new set of trick flow aluminum heads. where can i get the chip??
Old May 30, 2007 | 01:20 PM
GRX's Avatar
GRX
Talk to Greg at http://blowerworks.net/ Call him at 201-891-4690. He can help you with your supercharger setup needs. Tell him Manny Brazil referenced you.
Old May 30, 2007 | 01:21 PM
Wheelman's Avatar
Wheelman
Alvin at pcmforless.com does a good job with custom programming.
Old May 30, 2007 | 02:36 PM
86VX1's Avatar
86VX1
what type of ecu did you get with your super ram?
Old May 30, 2007 | 03:05 PM
bill mcdonald's Avatar
bill mcdonald
tonyboo,
kinda off topic, but do you have some high res pics of that car in your sig?
I would like to see it
To Accel Superram
