'89 hop up
Old Oct 23, 2001 | 03:56 PM
loflite's Avatar
loflite
Default '89 hop up
Okay, here goes another question that probably has been asked a million times. Looking at trying to get around 385 hp out to the now stock L-98. What must be done and is it easier or less costly to go to a crate motor? Thanks for your help.
Old Oct 23, 2001 | 09:37 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: '89 hop up (loflite)
The stock "D" Al heads flow to about 350hp and pocket ported to over 400hp. Combine that with a good cam, valve train, intake & exhaust and you should be there. You've go mail on one set of mods that buld mid 300s. A guy in Cape Coral, Fl was running an '87 L98 in 12.0s (which would be very close) on the motor but went to the mini-ram and true 3" duals along with ported heads and custom grind to get there.
Old Oct 23, 2001 | 10:46 PM
AS84's Avatar
AS84
Default Re: '89 hop up (65Z01)
65Z01-I emailed you some questions.
To '89 hop up
