Rear end gear help
Old May 28, 2007 | 12:20 PM
cemittar's Avatar
cemittar
Default Rear end gear help
Im going to put my `87 D44 rear suspension up for sale soon so I need to figure out what gear ratio I have in it. How do you do this? I know there`s some numbers somewere I just can`t remember were
Old May 28, 2007 | 01:03 PM
Repzard's Avatar
Repzard
Numbers should be on the bottom surface of the carrier at the cover mounting flange.
Hope that helps you
Old May 28, 2007 | 01:42 PM
88espo's Avatar
88espo
If you are not the original owner you need to spin the driveshaft to check for sure. The amount of times it rotates before the wheel goes completly around will tell you what ratio you have.
Old May 28, 2007 | 01:47 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
If it's got the original ring and pinion and it came out of an '87 originally, it will be a 3.07. Counting the input to output turns as mentioned above will tell the tale. All '85 through '88 cars with the 4+3 transmission came with a D44 3.07.
edoad's Avatar
edoad
If you have it out. Count the teeth on each gear, divide the larger gear by the small.
Old May 28, 2007 | 01:51 PM
edoad's Avatar
edoad
May have spoke too soon. I see you dont have it dissasembled. Go with counting the turns and pick the nearest standard ratio to it. with the guy up there probably 3.07.
Old May 28, 2007 | 07:58 PM
cemittar's Avatar
cemittar
thanks
Old May 28, 2007 | 08:15 PM
CFI-EFI's Avatar
CFI-EFI
You don't need to check the ratio. Just sell it to me for cheap. I don't care what the ratio is.
RACE ON!!!
Old May 28, 2007 | 08:30 PM
Corvette Kid
RACE ON!!!
Get in line old guy, I was here first!
Old May 28, 2007 | 09:06 PM
cemittar's Avatar
cemittar
I will post it in the for sale thread when it is time. It will be the complete rear suspension for sale.
To Rear end gear help
