Mysterious Problem
Old May 28, 2007 | 04:53 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Default Mysterious Problem
I have a ’90 L98 w/ 94k. Just had new dual exhaust installed (no cats) because the old cats were rattling. When I got the car back, it was not running very well, so I tuned it up, new coil, module, wires, cap rotor, plugs and fuel filter. Timing is set # 6 degrees before TDC. The car will set a code 32, ERG Failure, which I believe is caused by a lack of back pressure, per the FSM.
The car still has a miss, especially when warm.
The strange part is that the drivers side of the engine (which is were the problem is) is running about 30 degrees colder that the passenger side. Why would that be? My mechanic friend does not think I have a bad cylinder, or head gasket. He is going to do a compression test on Wednesday.
I do not believe it is a fuel injector issue, as the car does not lose fuel pressure.
All comments welcome, thanks for your help.
Randy
Old May 28, 2007 | 05:31 PM
toptechx6's Avatar
toptechx6
The side with a dead cylinder will run cooler, less heat being generated.
Old May 28, 2007 | 06:11 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Check the O2 sensor in the drivers side pipe and make sure it is good.
Old May 28, 2007 | 06:57 PM
CFI-EFI's Avatar
CFI-EFI
Try disconnecting the vacuum hose to the EGR valve and plugging the hose. Also, make sure the EGR valve is fully closed and not leaking exhaust gases into the intake manifold during idle. Does it idle better in this test? It would also be a good idea to check your FSM to see what can cause the code to set.
RACE ON!!!
Old May 28, 2007 | 07:06 PM
RandyJ75's Avatar
RandyJ75
O2 sensor is new.
Old May 28, 2007 | 07:31 PM
patsfan's Avatar
patsfan
From: Swanton VT 2000 Navy Blue Mettalic M6 / 1991 Auto - Steel Blue 68,500 R.I.P
Old May 29, 2007 | 03:48 PM
RandyJ75's Avatar
RandyJ75
RACE ON!!!
Did as you suggested, no change. Car starts and idles fine, runs good when cold,just breaks up about 3000 rpm when warm. The warmer it gets, the worse it runs. Changed the coil, old for new, again ran fine when cold, ran worse when warmed up.
Car goes in for a compression check tomorrow.
To Mysterious Problem
