TPI plenum cleaning.
Old May 28, 2007 | 10:02 PM
larryfs's Avatar
larryfs
Default TPI plenum cleaning.
Is there a chemical that will remove the old gaskets from TPI runners, and plenum? Seems the factory gaskets are stuck on there pretty well, and the alumunim is rather soft, and I don't want to risk damaging it.
Old May 28, 2007 | 10:29 PM
Danspeed1's Avatar
Danspeed1
Carb Cleaner, Brake Parts Cleaner, maybe Sea Foam.... alot of scrubbing,
DG
Old May 28, 2007 | 10:40 PM
86PACER's Avatar
86PACER
How about this?
Old May 28, 2007 | 10:50 PM
Benny42's Avatar
Benny42
Permatex industrial gasket remover #81110. Its strong stuff, wear gloves. I use it on a/c compressor head gaskets. The can says it has methylene chloride. Be careful. benny
i type slow.
Old May 29, 2007 | 10:23 AM
Aardwolf's Avatar
Aardwolf
A grinder with a brush on it will help to.
Old May 29, 2007 | 01:14 PM
Square's Avatar
Square
I use a plastic putty knife. It lets you dig in hard without worrying about the aluminum.
To TPI plenum cleaning.
