While doing a bit of work on the car, just for the hell of it I decided to check the manifold bolts. The car is stock and has never been touched in that area. I have an oil leak issue there. They were all loose. Everyone of them were only torqued to 10 lbs or less. The only one I couldn't really get to was the one under the throttle connection on the TB. Any advice on that one? Hopefully this will at least slow the leak. I would suggest that anyone whose car is stock and hasn't been touched to check also.
The work I was doing was replacing the coil and ICM. Hoping that will fix the stumble and hesitation on acceleration and cutting out in the upper rpms when hot. Will report back on that. Drove the car twice since and no problem yet. It seemed to pull a lot smoother. I'll see this afternoon when the temp is around 90. I've got my fingers crossed.
If I remember, is the intake bolts torque spec something like 19 ft/lbs ?
I would like to see someone with more expertise than I have to step in and explain why we might see differences of this magnitude and the consequences of following the different instructions might be.
I don't have a technical answer since I didn't design the LT1 manifold. The difference could because the instructions you have are pertaining to the L98 and not the LT1. The LT1 has different heads too.
A problem I have with people "checking" is that the bolts should be Loctited and some will have thread sealer. What happens to these when the owner gives them a turn?
If the intake manifold bolts were locktit'ed by previous owner(s), then I would prefer to break the Locktite bond and torque to spec, as these bolts should NOT have been locktite'd in the first place. Locktite would not allow for re-torqueing after running engine a few days to adjust for RTV/Gasket settling.
...BTW, what's up with the large variance of 25-45lbs for the '86 !! That's seems crazy to me....
I can tell you right now 10 ft lbs. is very bad. I'm in the process of redoing my bolts as we speak. The first time I couldnt get one of the bolts to get more than 10 ft. lbs. on it cause it was stripped. Needless to say, I blew my intake gasket. The intake bolts are supposed to be between 20 and 25 ft. lbs.
My GM Factory Service Manual says to use Loctite 1052624 or equivalent. Can't determine exactly what current Loctite product is equivalent but my CF search suggested a thread locker. Holly says use 242 Blue.
Or you can go el cheapo and just use black RTV and it works just as good.
