Plenum fittings - sealant?
Old May 29, 2007 | 06:49 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
Default Plenum fittings - sealant?
When I removed the vacuum fittings on the plenum (87 L98), there was "gunk" on the threads. I can't tell if this is just 20 years worth of stuff or should I use something on the threads when I put them back in?
TIA,
Gary
Old May 29, 2007 | 06:57 PM
rel3rd's Avatar
rel3rd
I put sealer on any threads that seal any type liquid or vacuum.
Very cheap insurance...
Old May 29, 2007 | 07:01 PM
Aardwolf's Avatar
Aardwolf
TIA,
Gary
I did. I had to clean some of that off to. The stuff is so old and hard that it obstructs the threads. How's it going? I used Teflon pipe thread sealant, high temp for autos.
Old May 29, 2007 | 07:38 PM
RRT vette's Avatar
RRT vette
Old May 29, 2007 | 11:23 PM
ghlkal's Avatar
ghlkal
Thanks for the responses, guys.
Is this different from "normal" teflon tape? Where'd you get it?
Andrew, I'm going to "invite" you over next week (there's a wedding this weekend ) and have you give us some pointers ...
Gary
Old May 30, 2007 | 10:34 AM
Aardwolf's Avatar
Aardwolf
Sounds like fun! Just let me know when.
The normal teflon sealant does not say for high temp. so I always used the tube that says high temp. for automotive use. Fleet and NAPA should have it. I can bring some with if you still need it, a large tube lasts forever. Many other bolts get locktite or never seize, some do not get anything so as to have a ground.
To Plenum fittings - sealant?
