great news.....NOT!
Old May 29, 2007 | 07:10 PM
96 lt-4's Avatar
96 lt-4
Default great news.....NOT!
so i drop my car off at CAM for jeff to install my hotcam,EWP,and retune it.it has had a nasty lifter noise for some time(or so i thought it was a lifter).
so i get the call today,"the noise is not coming from your lifter it's coming from your timing chain/gears rubbing against the block because the thrust bearing on your crankshaft is shot and the thing is walking back and forth at least a 1/2 of an inch".
so when i get home my wife says "hi honey,how as your day?"i am glad i remembered she is my wife and i have to live with her.
oh did i mention 2 of my 3 motorcycles are in the shop also?and my dodge was scheduled to get painted and the interior redone next month.oh yeah,i just spent $500 for a fiberglass hard top that still needs to be painted.
i keep putting miracle grow on that tree in the backyard but it is'nt dropping any money.
anyone want to buy a honda 900RR?
it will all be fine.i just needed to vent.i will find out the extent of the damage tomorrow or the next day and proceed.
before any of you smart asses say STROKE IT DUDE i would love too,but the money aint there.
there i feel better
Old May 29, 2007 | 07:21 PM
derekguzz's Avatar
derekguzz
ill buy it for 2 g's
Old May 29, 2007 | 07:25 PM
96 lt-4's Avatar
96 lt-4
sure,i'll sell you the crank with the toasted thrust bearing for 2g's.what a great guy!and to think,all those comedians out of work!
Old May 29, 2007 | 07:39 PM
Carpenter's Avatar
Carpenter
Sorry to hear of your crank problems George.
Not to put too fine a point to it, but your main thrust bearing is only about 1/8" to 3/16" thick. So if your mechanic was being accurate (1/2" play)....you MAY be looking at a new crank (or weld up/machine down) as a BEST case. Worst case is the block surface is toast as well.
Lets HOPE it's ok.
Old May 29, 2007 | 07:50 PM
cv67's Avatar
cv67
St. Jude Donor '05
The crankshaft bit is BS. If it were true, youd hear a lot more than lifter type noises....Heck youd throw the belt every time you ran the car. Best of luck! How many miles on it?
Old May 29, 2007 | 07:55 PM
Demonic85's Avatar
Demonic85
This happened to my gf's '77 C10 and it was making a lot of noise before it died.
Old May 29, 2007 | 08:06 PM
CFI-EFI's Avatar
CFI-EFI
Maybe it is really the thrust on the camshaft that's shot. Actually, if the crank IS bad, you are more than half way to a 383, just in repairs. Then there wouldn't be any question of what to do.
RACE ON!!!
Old May 29, 2007 | 09:28 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
While 1/2" is probably a bit of an overstatement, I've torn down some engines that had some pretty severe wear to the thrust areas. Remember, if the wear is bad enough, it'll be not only be the thrust surfaces of the bearing but also on the matching crank surfaces. And I've often seen this with no other unusual wear on the other bearing surfaces. So if you add up both sides of the thrust bearing and their matching crank surfaces, the wear, and so the amount of end play, can actually be quite a bit. I'd bet that I've seen as much as 3/8" or damn close to it.
Old May 29, 2007 | 09:43 PM
LD85's Avatar
LD85
RACE ON!!!
no way a crank can go 1/2" , must mean the camshaft, crank does not have a thrust bearing but a cam does
Old May 29, 2007 | 09:59 PM
CSS996's Avatar
CSS996
I used to have a '98 CBR900RR. Yellow. I miss that bike! Hopefully your tree will start sprouting soon! :o
Old May 29, 2007 | 10:00 PM
STL94LT1's Avatar
STL94LT1
Old May 29, 2007 | 10:01 PM
LD85's Avatar
LD85
Actyally , it is probably the cam button is gone / bad
Old May 29, 2007 | 10:03 PM
Corvette Kid
Au contraire..... The crank has a thrust bearing, the cam only a thrust plate. In some engines, the cam doesn't even have that, such as in older small block Chevys.
Old May 29, 2007 | 10:33 PM
LD85's Avatar
LD85
Semantics, ,, so can you buy a separate crank thrust bearing
Old May 29, 2007 | 10:44 PM
Carpenter's Avatar
Carpenter
Point is that the LT4 does have a thrust plate.
Based entirely on what he was told by his (apparently trusted) mechanic, the crank thrust bearing is shot along with his crank AND his block. (assuming the mechanic was accurate in his statement ("at LEAST 1/2" play"). Which also calls into question the entire rotating assy, of course. (rod thrusts, pistons, walls, etc, etc.)
It's ALL about just how much play you have. Before even paying to open it up, I'd insist on an accurate end play measurement. If it's UNDER 1/2" it's worth going further. If it's OVER 1/2" it's not worth paying his labor just to tell you it'll be cheaper replacing the entire short block.
Old May 29, 2007 | 10:46 PM
Carpenter's Avatar
Carpenter
LD85,
One of the main bearings has the thrust bearing as part of it.
Old May 29, 2007 | 11:06 PM
Corvette Kid
To great news.....NOT!
Old May 29, 2007 | 11:14 PM
Carpenter's Avatar
Carpenter
Biography:
Winner of the prestigious, 7 day, all accommodations paid Corvette Forum deluxe vacation package.....
How was it?
Old May 29, 2007 | 11:37 PM
cv67's Avatar
cv67
St. Jude Donor '05
Veteran here
I got a lot done on my time off
Old May 30, 2007 | 12:56 AM
Klondike's Avatar
Klondike
Must mean cam thrust clearance is shot. The crank wouldn't move that much because there isn't 1/2 inch of clearance on the rod journals, and I don't think you could push all 8 rods 1/2 inch back and fourth on the wrist pins of all the pistons either. Start it up and have a look at the front balancer while somebody pushes in and out on the clutch. I bet you can't even see the balancer move forward at all. If it moved at all, I'd duck and run! LT4 cranks are special ( a LOT more machining than an LT1) and I don't think you're going to push one around like that without the engine turning into "junk with a clunk"!
