Is there a secret to installing upper door and top weaterstripping on c4's? Mine leaks at the upper corners and runs down into the floor just above the front speakers?
I believe they all leak in this area.
I have seen some gutters in the catalogs.
Don't know if they will help here though.
Mine leaks there also, but only if it is sitting out in the rain.
doesn't leak when i wash it or am driving it.
There is no question that GM weatherstripping is a better choice. The aftermarket weatherstrip is known to be hard (much less flexible), provide an improper fit, and leak. Yes, there is a price difference, but in my opinion, it simply is not worth the money saved. :nonod:
Ok...so what I get from this is that the weatherstripping to get is from a 95 or 96??? I thought it was the same for 84-96. Is corvette-rubber a good place to get it from?
