LT4 won't start
Well I left my car for 6 days while we were in New York (great city! very friendly), I got back and it turns over but won't fire up.
It's definitely fuel. Spark is there and when I first cranked it, it fired immediately then died as if it was burning up fuel sitting in the rails, etc. The gauge reads 3/4 and I poured in some extra just in case.
Couple of questions:
- How many fuel pumps does the LT have? I remember reading 2. I hear a hum from the engine bay for a couple of seconds when key is in On position, and after a failed crank. Is this a fuel pump?
I don't hear a hum from the in-tank pump, just a click. I stuck my head under there while someone else turned the key to On and off again. Then again I have never noticed a hum from the rear pump, and I always hold the key in On position for a second or two before cranking to prime it (old habit).
- Is fuel pump failure common on later C4's?
mine's at around 90,000. I found several related threads but they were all 85/ 86 cars. It seems weird that it would be fine when I left it then complete failure after not driving for 6 days. I had noticed it taking longer to start since I changed the plugs and leads recently. It used to start almost immediately on turning the key.
- I want to/ should buy the FSM. It's 120 bucks from the Helm site - anywhere I can find this cheaper? I thought it was more like 50 bucks.
I will try replacing the in-tank fuel pump first. Hoping it's this and not something nasty electrical. At least it's parked at the in-laws where I can work on it
Get a fuel pressure gauge and test the fuel pump before replacing it. Could be something else and you will be replacing a good part. Could also be injector ref pulses. Does the battery have a good charge?
Yes the pump quits when it wants to. Mine went south at 28,000 miles.
I forgot to mention I did check the fuses - first thing I looked at. All ok. At least now I know where all the fuses are
Here's what I did:
-Checked fuel pump fuse, swapped with internal lights fuse (20A), tried to start - no start.
-Bought a voltmeter, pulled an injector plug, checked for volts across plug with key in On position - had voltage.
- Pulled fuel pump fuse and turned over to clear system of fuel, attached fuel pressure gauge to schrader valve, replaced fuse, turned key to On position, checked pressure - zero fuel pressure.
I was pretty sure it was the fuel pump at this point.
Went to local NAPA store, bought fuel pump, pump loom and fuel pump sock. The NAPA guy asked me if it's true what they say about owning a Corvette being a lifestyle. Maybe it was my Vette cap and sweaty dirty face
I told him all about Corvette Forum I the followed procedure in my work manual and on this excellent thread from Frizlefrak here
It was a fairly easy job for a first-timer, I just took my time and tried not to drop things in the gas tank or blow myself up. The hardest part was getting the hoses off the pump assembly. I bought the wiring loom too but decided not to try it after reading I had to splice 2 wires together. I examined the existing wires and connections - they seemed pretty good to not take the risk with my horrible wiring skills!
Pics:
Taped up gas nozzle hole and cleaned up area after removing gas door and rubber surround
Had to take a trip to Autozone to get Torx bits to get the gas door screws out
This hose clip was a bitch and took a lot of pursuading with a screwdriver
Pump assembly removed, taping up hole above lake of gasoline
Pump assembly out
Another view, checking wiring positions
Removing harness - these clips need to be pushed in to remove plug
Checking original sock position before removal
Old pump on left, replacement on right
Completed assembly with new pump and sock
Now turning the key I could hear the pump whizzing up, turned it over and she instantly started up!
Thanks all and see you on the road
Just curious, how many miles did you get out of your old FP?
