Question on 84 engine swap
*I addressed the center intake manifold bolt-to-head holes by simply using a die grinder to oblong the holes, and mill a flat "pad" on the boss where the original bolt hole was. It worked fine for years, and I later installed a SBC 400 (same head/manifold bolt pattern as your STOCK motor again), and w/o any further modification the CFI manifold bolted onto the 400 and worked fine, for years.
*The Truck motor uses the infamous "swirl port" heads, which are garbage, from a performance stand point. They flow terribly, and you'll LOOSE hp by switching to that long block, because of the heads. It also features the wimpyest cam GM ever used: less than 200* duration on both sides and about .400" lift on both sides. Pitiful. In the truck, w/a dual plane TBI intake, TBI, and the truck exhaust manifolds, it made 190 hp.
*The truck engine uses a 168 tooth flywheel, my Trans Am used a 153. I'm betting that the Corvette uses a 153 too.
The motor will function fine, give you decent gas milage (I got 25 hwy in my Trans Am) but it won't win many races.
I'm not really concerned about the HP as much as the MPG because I plan on using it as a daily driver. I can probably get a flywheel from a junk yard pretty cheap.
Getting it up and running is the top priority. Making it 'go fast' will come later. Probably much later.
Thanks.
on the 'freak out'.I just got some more info on the engine from the guy I'm buying it from.
It seems that for my $200, I am getting the long block, intake, exhaust, alternator, starter, water pump,flex plate and belts.
All on an engine with only 31,000 miles!
He had wrecked the truck and pulled the engine with everything still attached!
I'm picking it up sunday afternoon. Can't wait.
I've never been under mine to count the number of teeth on my 96 LT1 flex-plate, I just assumed it has 168 teeth. I need to order one for the engine I'm building and just want to be sure I order the correct one.
Take me to school.
Thanks,
Jake
RACE ON!!!
There is a ton of misleading, erroneous, and just plain wrong "help" in this thread. You have been given lots to worry about where there is no worry. Forget flat top or dished pistons and compression ratios. Don't worry about exhaust manifolds. Your old manifolds will fit the new engine and the car. If both your car and the truck are autos, and the truck flexplate has 153 teeth, the truck flexplate is the answer. Otherwise some research will have to be done. We will need to know manual or auto for the 'wheels and the tooth count from the truck unit if both have the same type of trans. The 1994 truck engine is NOT a vortec, so none of the vortec differences apply here. Reread my first post and the one from Tom400CFI. Follow his advice on using your manifold with the later heads. My two posts and Tom400CFI are all you need to read for your swap. Many of the other post have you concerned about things that don't apply here. This is a relatively simple swap.
RACE ON!!!
RACE ON!!!
From a "swap" point of view, it does not get any easier than this.
IMHO,
all you need to do really, is take your 84 engine out, disassemble it, and buy a rebuild kit from Northern Autoparts .com, and fix your old engine. The engine kit will set you back less than $200, and they have higher cost options that you can use, like cam changes, and so forth.
They even throw in the pistons. I bought one of their kits, and the only problem was I didn't need the pistons, and have been dreaming up engine combos to use them in.
You will have to address worn heads, but if all you want to do is daily driver stuff, a local machineshop can do a simple 3 angle valve job on them, or you can find some low cost heads somewhere
If you use your original engine, when it comes time to either restore it, or sell it, you can be one step ahead of the process in retaining all of your car's original parts, and maintain it's value to either a collector, or your satisfaction that you have a numbers matching car.
RACE ON!!!
From what I understand, the truck was an automatic, and so is my vette. I'm hoping the flex plate is the correct one. If not, then I'll shop around for the right one.
I had already figured on using most of the parts, that are still good, from the vette. The alternator on the vette either needs a rebuild or needs to be replaced because it was 'stuck' when I first got it. I freed it up, but I just know the insides are probably rusted to heck.
I did manage to get the starter working again by taking it out and cleaning it up, but I just don't trust it. I'll probably use the one that comes with the truck motor.
I figured I probably needed to change the water pump. I found a lot of useful information here on the forum and did a lot of reading because I wanted to be as familiar with the vette as I could before I got into it.
I plan on using Tom400cfi's suggestion and have the intake milled flat where the center bolts go.
Once I get the old motor out I'm going 'test fit' it in the vette and then I'll start swapping whatever I need.
The reason I'm going this route is because (1) the old engine has 122,000 miles on it and I don't know the condition of the valves,cam, lifters, bearing etc. And (2) for $200 I can save myself a lot of money for now and still have a running car.
Like I said earlier, I really don't have a lot money and I've always wanted a vette. When this one came up cheap, I just jumped on it blindly.
There is still the concern of the transmission as well because it was 'water logged' too. I'm hoping I can flush it out and get it working again.
I really appreciate the information that you and Tom400cfi have given me, as well as the suggestions from others. It helped me to make the decision to buy the engine.
I know it's going to be a long process to get it going again, but I can do all the work myself.
Thanks again.
At my age (which I'm not going to tell.
) this is probably going to be a one time shot for me.Luckily I have a son-in-law that's a fairly competent mechanic and he's offered to help.
There is the first time you know you'll own a 'Vette. There is the day you finally get one....then there is all the time in between.
For me, the "time in between" was about 30 day-dream filled years.
When you get finished, you will wonder what it was that you were worried about. If I can help along the way, just shout.
RACE ON!!!
If the truck alternator will fit the '84 brackets, you will be able to use it.
If the truck had V belt driven accessories (I think it did) then you will HAVE to use the '84 water pump as explained above.
You can touch it up with a hand grinder. There is no need to have it milled.
No need for a "test fit". They are two peas in a pod. It will be easier to swap parts from one to the other while on a stand.
RACE ON!!!
I may not get everything fixed on the car this summer, but at least I'll be headed in the right direction. But, who knows. There's still at least 4 months, if you count September, to get it done.
Gotta run to the bank. Sunday is just two days away and I want to have the cash on hand!
That was in 1966...Ooops! (hope I didn't give my age away)
RACE ON!!!
RACE ON!!!
Thanks for that info. I only wish the Forum has notified me of your response because, as you might now guess, I ordered the wrong one!
Now I have t return it and order a 153 toother.
Thanks again,
Jake
Today is tuesday, and it's going back.
Turns out the engine is a 305 NOT a 350.
The person I bought it from said it came from his buddy's truck and the emblems on the truck said 5.7 liter. Well, in my search for a gasket set I ran across a website talking about 'casting numbers'.
Soooo, I went out and looked and came up with the number 14102058.
I looked it up, and sure enough, it's a 305 made between the years 1987 and 1991. Now I don't know if his 'buddy' had his engine replaced on his '94 truck. But if he did, and it originally was a 350, the I'd say he may have been taken to the cleaners by a rather shady shop.
Either that. Or he lied! But, I'll give him the benefit of the doubt.
Either way. I called and told him I was bringing the engine back and wanted a refund. He said ok. So maybe it was an honest mistake.
At any rate. I learned something I didn't know before about 'casting numbers' on chevy blocks.
Now I'm debating just pulling my engine and going over it anyway, or try to find another 'deal'.
I guess the old adage 'If it seems too good to be true, it probably is' should have been my first clue.
BTW. I even talked him down to $160!!
