Thanks for all your input. I'm still not 100% convinced its the tensioner but I wont rule it out as a possibility. If i've exhausted all options in the FSM then I guess i'll just buy a good used one like Midnight did. My idle always seemed to bounce around anyway.
Your belt tensioner will not cause idle hunting- unless the bearing is frozen or something else in your belt train has issues. Idle hunting is due several possibilities- IAC, MAF, etc. If you have an FSM it is a matter of rule outs. Vacuum leaks are the number 1 cause of poor or rough idle and or performance. If you have poor fitting aftermarket intake parts or heads- that would be a good place to look.
There is no way belt tension can affect the idle. Get real! It didn't cure the idle for Midnight 85. It just gave him a S.O.T.P. improvement. If the spring tension on the idler pulley is weak, an erratic idle, as it surges, could cause the pulley to move up and down. But it is the idle that moves the pulley, not the other way around. And if you can easily move the idler pulley by hand, the spring is weak.
You should look for a good wrench in your area,and get it fixed,you will be money ahead.It is prob something simple.
Did the car ever run right after you switched heads?maybe you have a colapsed lifter?
Yes, the car ran great after I put it all back together. I didnt get up on it a lot either. I would love to have a good mechanic work on my car to tell me what the problem is, but that is the my biggest problem of all. I've tried many mechanics and they get progressively worse every time i'm recommended to a new one. The last guy broke a valve cover bolt off IN my head and left it there. I'm afraid to take it a specialty shop because of getting ripped off. Dealership is out of the question.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
There is only one good solution. Learn. If you're patient and willing, and know righty-tighty lefty-loosey, I can walk you through the rest. Don't be intimidated, millions of high school drop outs are making money doing it.
first, the tensioner should be replaced because the spring is weak.
second, the tensioner possibly could be playing catchup, and jerk the belt, but all that would do is slip on some of the reverse rotation pulleys.
Third, vacuum leaks don't cause surging, but
A. dirty ioc's do,
B. poor connections on the oxygen sensor does,
C. loose connections at the distributor does,
D. Intermitent heavy electrical loads do,
E. dirty fuel socks in the gas tank do, etc.
OK a little update guys. I decided to test the Ignition Coil and the pickup coil since it seems like a possible cause. Sure enough the coil pack failed the test so I bought a new one. It didnt help though.
with Coupeguy2001 that vacuum leaks will usually cause it to stall out, rather than cause a hunting idle. All my vacuum lines are good as i've probably checked them all at least 5 times by now. He also mentions that a bad connection with the O2 sensor can cause it. This concerns me because the day before it started running like this, the wire was laying on the exhaust pipe and it was smoking. I looked at it and it seems ok, but doesnt mean that it is.
