header wrap......yes or no!?
Is there any "must do's" when doing this or is it pretty straight forward,easy to do?
I had installed a tubular steel header on my brother's old Honda Civic CRX Si a few years back. Because the header was just mild steel (like the stock exhaust on the L98) I decided to use header wrap instead of getting the header coated. At first, the results were very impressive. The header wrap did an excellent job of containing the heat and underhood temperatures dropped dramatically! In fact, you could run the car all day long and actually TOUCH the header immediately after shutting the engine down - it did THAT good a job!!!
As time went on, however, this proved to be it's downfall. The header tape contained the heat so well that it actually caused the header to crack! And because the header was wrapped, my brother didn't realize it until weeks (or maybe even months) after it happened. I ended up reinstalling the CRX's stock manifold after that.
So the moral of the story, if the headers you are wrapping are just mild steel (like the stockers), chances are good that they will end up cracking, so don't bother - you're better off getting them coated. If the headers you are wrapping are already coated and you're looking to augment the coating, then go ahead and wrap 'em.
Oh, and I should also mention, header wrap isn't exactly the prettiest thing you've ever seen (in fact, it's pretty down-right ugly IMHO), and it will have no effect on muffling any exhaust noise coming from the engine.
Hope that helps.
Hope that helps.
I bought the wrap and decided not to use it after playing with it. The problem is that you need to minimize the overlap per the installation instructions. With the header curves, minimizing overlap on the wraps is not possible.
To help cool down the engine compartment, I punched out some 3" holes in the side of the upper fenderwell cover. This provides a higher point for hot air to escape. The fender vents are too low. No problems with water.
QUOTE]
Severe fire hazard, acts just like the wick of an oil lamp. Definitely a bad idea, especially in a fiberglass car!
I think he means if it just happened and it was not caught. I still standby that it captures moisture and will mold and does NOT do its job but thats my opinion. LOL, you should change your name. You seem nice to me but no one else?
Rust bubbled up under the wrap(at the collector).
Ya gots ta keep it clean as you can. No oils dripped on it, no greasy/dirty hands touching all over it.
Mine caught on fire
Here is the hilarious thread(the pics are gone now tho-sorry)
http://forums.corvetteforum.com/showthread.php?t=573073
Mine caught on fire
NOOOOOOOOOOOOOOOO! I remember that thread! Paul....im gonna donate a spare 350 to you to get things running again! I miss hearing your car on the road.
Your like the one of my top fav members now. LOL. Dry sense of humor with sarcasim and for once your jumping down someone elses throat for my entertainment. lol
