4+3 trans problem
Old Jun 3, 2007 | 02:18 PM
zack3211's Avatar
zack3211
8th Gear
Default 4+3 trans problem
the car has been sitting for a wile i think the clutch is stuck to the pressure plate. i have been told to take off in 2nd and hold the clutch but i am not able to do this would i be able to do this in a garage on jack stands? can someone help me pls i really need it
Old Jun 3, 2007 | 02:56 PM
Repzard's Avatar
Repzard
Yah you should be able to do it on jackstands .
just make sure your car is stable and chock the front tires on both side in the front and backside so it cant rock in anyway and slip off jackstands.
Check the fluid in master, sounds like your hydrolics are not working or you have a bad slave.
Does the clutch pedal have pressure ?
Old Jun 3, 2007 | 05:02 PM
zack3211's Avatar
zack3211
8th Gear
i thought because of pressure the master was broke and i removed it I accidentally cleaned it with carb cleaner and broke it so now i need a new one the clutch had miminal pressure on it when the master was in.
To 4+3 trans problem
