84 courtesy light problem
Old Jun 4, 2007 | 06:43 PM
da747's Avatar
da747
Default 84 courtesy light problem
The interior lights in my 84 recently started staying lit constantly with the ignition in the off position. (between lock and on) if i turn the key on they go out while the dash lights as one would expect, but then as soon as i turn the ignition back to off the courtesy lights come back on. this is with both doors and the hatch closed. is this likely a ground, or the courtesy light timer? also on a different note, under the distributor/ignition section, the FSM clearly instructs to route the #'s 2 and 3 spark plug wires around the front of the distributor. could they possibly cause intereference with the ECM/ignition harness if they are routed behind the distributor?
