5.3 v8 or ...
There are kits to make a distributor drive off the cam, and put a carburetor on it.. I would think that you could pay some one to make adapters for a dual quad manifold, and use your throttle bodies and make them a little lower than they would sit if they were mounted on top of the manifold.
Then you would be able to keep all of your factory electronics and your hood intakes if you modified the throttle body air horn adapters.
Then you would have to figure out the trans, and the rear trans mount would have to be fabricated, or use a truck trans, but that would be clunky.
Clunky has no place in a corvette.
RACE ON!!!
Might want to get the July 07 issue and read the "First Turn" section.
They also have a blog going at www.corvettefever.com regarding the swap.
but the motor mounts are the least of the problems. There are kits to
clunky.
- The 5.3 is an LM series, not an LS series engine.
There are LM4, LM7 and L33 versions of the 5.3. The LM series have
Fe/Al blocks/heads (as do the larger LQ series - 6.0 & 6.2.) The L33
and the LS series are Al/Al. - The 5.3 is physically different to a GEN I 350: outwardly and in
terms of displacement.
As has already been stated above, considering the effort and expense
of this swap my vote is that the larger displacement version is the
preferred choice. There is little if any difference in price between the
LM and the LQ choices but there is a sizable difference in performance.
Still, in the spirit of supporting alternative thinking, I suggested that
if small (5.3L) is good, tiny (4.8L) might be better.
The 4.8L LR4 engine is a 293 ci version of the GEN III engine that has
almost as much OEM HP as the 5.3
- 285HP/295TQ @ 5600/4000 - vs - 290HP/325TQ @ 5200/4000
but with a shorter stroke (3.270" vs 3.622") the LM4 is capable of much
higher RPM (3,540 FPM vs 3,924 FPM Piston Speed @ 6,500 RPM).
Presumably, the same logic used to predict that the 5.3's would be
priced lower than 6.0's would see the 4.8 being priced even more
attractively. However, in the thread below the 4.8 was deemed too
small by those who thought the 6.0 was too big.
Here's a discussion of the article.
Corvette Fever- Project C4orce- Have you heard?
Melrose announced they were preparing to release headers for the
GEN III / C4 swap.
LSx Engine Swap into C4- Headers Avail Soon
As a final thought, Trace's '84 LS1 C4 is listed in the C4 Cars for Sale
section.
F/S 1984 LS1 Vette
Sorry, cuisinart. I didn't notice your link to LS1C4's thread before posting.
My major hurdle is the trans bracket I bought that was supposed to work didn't. It's a POS. So I'm spending time fabbing one up.
